Tip & How-To about HP LaserJet 1022 Printer
Spooler crash with Vista
When the spooler craps out under Vista, the easiest fix is to use the restore option in system tools and reload the previous configuation. I have this problem everytime I try to read a large PDF file in Outlook.
HP LaserJet 1022 Printer Logo
i have a vista laptop and need 2 reboot back 2 factory settings how do i do it
To restore your laptop to its previous or factory settings try using the system restore option. You can access the System Restore by navigating to Start--> All Programs --> Accessories --> System Tools --> System Restore. After opening the System Restore Tool you select this option " Restore computer to an earlier time". Then you can see the calender displaying the present month and some bold dates in it. You can go back to the month of the purchase your computer and then select one of the bold dates and click "Next". Then the system will restore and it re-starts on its own. A message will be displayed after Restoration is completed. Press "OK" . Thats it, your Computer is set in to Factory Settings. If you face any problem please let us know. Thank you for contacting Fixya.
Nov 10, 2009 | Microsoft Windows Vista Home Basic Edition...
wont boot up starts up and go into windows but isnt showing icons ot task bar and i cant use my recovery disc that came with my notebook
a regular XP or Vista installation cd will work as well.... for a recovery if you have one on hand try a System Restore first if you can under : Start/Programs/Accessories/System Tools this process will take a while to shut down and reload so be patient.... make sure to select a previous restore point
Aug 05, 2009 | Acer Aspire 3690-2196 Notebook
i have vertical lines on my computer when on my monitor
What game did you download and also check your monitor and connections to it they might be loose of have a small short....
what is your operating system? for example, XP or Vista If you have either one of those the easiest way to fix that problem is to do a system restore located under the start menu button/ programs/ accessories/ system tools and select a previous date on the calender or previous save point. "note you may loose a program that was recently installed or file data so back that up before doing so just to be on the safe side" all else fails a reformat should fix that..... good luck!
Jul 28, 2009 | Acer Computers & Internet
I had to restore computer settings and my wireless G Notebook card is not working....
What operating system you had and whether you got a windows based system like xp or vista you have a restore option in your system tool sun the restore and get back to a previous days which everything works fine but in your case i hope you have to check from the wireless switch and the device driver for the wireless card, if status for both are ok check for wireless zero configuration service running under administrator tools /services
Jul 05, 2008 | Belkin Computers & Internet
2,234 people viewed this tip
Seeker5211
Seeker5211
