Tip & How-To about Jeep KNG36-JXLWBC AM/FM/Weather Radio
SAFETY 1. HANDLE WITH CARE AND AVOID CONTACT WITH CORROSIVE LIQUIDS. 2. AVOID LEAVING YOUR UNIT IN DIRECT SUNLIGHT OR IN HOT, HUMID OR DUSTY PL.ACFS 3. KEEP YOUR UNIT AWAY FROM HEATING APPLIANCES AND SOURCES OF ELECTRICAL NOISE SUCH AS FLUORESCENT LAMPS OR MOTORS. 4. ALWAYS TURN YOUR RADIO OR LANTERN OFF WHEN NOT IN USE AND REMOVE BATTERIES IF YOUR UNIT IS NOT GOING TO BE USED FOR LONG PERIOD. 5. OLD BATTERIES CAN LEAK AND CAUSE CORROSION DAMAGING YOUR UNIT. 6. LAMP BULBS OR LANTERN SHOULD ONLY BE REPLACED BY QUALIFIED TECHNICIAN. NOTE: OUTPUT POWER: FM-550 mw, AM-405mw
Jeep KNG36-JXLWBC AM/FM/Weather Radio Logo
the dehuminifier run but it does not collect any water
The basic things that cause this problem are easy to troubleshoot and solve.
1. The humidity extraction level is set to HIGH. Lower it to 35% or less.
2. The air intake filter is dirty or clogged. Remove and clean the filter following the Owner's Manual's directions on "How to clean the filter."
3. Not enough clear air space around the unit. Maintain a minimum of 12" Clear Air Space on all 4-sides of the unit.
4. The ambient air temperature at floor level is between 40 & 60 degrees F. If the unit is a basement, the air temperature at the floor level is colder than the air temperature at chest level. Place the unit on a sturdy table or counter, that can handle the weight of the unit, plus a full tank of water.
5.. Do Not operate the unit in direct sunlight. Close curtains or blinds as necessary.
Troubleshooting the 5 things listed above should help you solve the problem. Please let me know. Thanks.
Jun 08, 2011 | LG LHD45EL Dehumidifier
Instructions required to replace the maintence kit for a Kyocera FS4020DN
You must unplug your printer before doing any work and be very carefule not to damage any of your parts.
(1) Precautions
Be sure to turn the power switch off and disconnect the power plug before starting disassembly.
When handling PWBs, do not touch connectors with bare hands or damage the PWB.
Do not touch any PWB containing ICs with bare hands or any object prone to static charge.
Use only the specified parts to replace the thermal cutout. Never substitute electric wires, as the printer may be seriously
damaged.
When removing the hook of the connector, be sure to release the hook.
Take care not to get the wire caught.
(2) Drum
Note the following when handling or storing the drum.
When removing the drum unit, never expose the drum surface to strong direct light.
Keep the drum at an ambient temperature between 0 °C/32 °F and 40 °C/104 °F and at a relative humidity not higher than
90% RH. Avoid abrupt changes in temperature and humidity.
Avoid exposure to any substance which is harmful to or may affect the quality of the drum.
Do not touch the drum surface with any object. Should it be touched by hands or stained with oil, clean it.
(3) Toner container
Store the toner container in a cool, dark place.
Avoid direct light and high humidity.
(1) Detaching and refitting the developing unit
Procedure
1. Open the top cover.
2. Open the MP tray.
3. Remove the developing unit.
4. Check or replace the developing unit and refit all the removed parts.
(2) Detaching and refitting the drum unit
Procedure
1. Remove the developing unit.
2. Open the left side cover and then remove the waste toner box.
3. Unlock the drum unit lock and then remove the drum unit.
4. Check or replace the drum unit and refit all the removed parts.
(3) Detaching and refitting the fuser unit
Procedure
1. Draw the rear unit.
2. Insert a flat-blade screwdriver to push the fuser lock (gray colored) on the rear unit and the fuser unit is separated from the rear unit (rails).
Do it both ends of the rear unit.
3. Check or replace the fuser unit and refit all the removed parts.
Place the fuser unit on the rear unit (rails) and push the fuser lock so that the fuser lock catches the fuser unit.
Do it for the both ends of the fuser unit.
(4) Detaching and refitting the transfer roller and separation charger brush unit Procedure
2. Remove the drum unit.
3. Slide the paper chute guide and unhook the hooks.
4. Remove the paper chute guide.
5. Remove the shaft (transfer roller) from the both bushes.
6. Release four latches and then remove thecseparation charger brush unit.
7. Check or replace the transfer roller and separationccharger brush unit and refit all the removed parts.
CAUTION: Note the following, when refitting the separation charger brush unit.
A. The separation charger brush unit is inserted into the two projections of the frame and does not run on to the projections.
B. The separation charger brush unit is firmly in contact with the separation charger plate of the frame.
The last things to replace would be your rollers which just pop in and out.
Jan 19, 2011 | Kyocera FS4020DN (A4) Workgroup Mono Laser...
Changing Tax Status on departments?!?!?
How do you do. I have an manual on AL 1631 write me on goodgold@inbox.ru I am Sergey. I come you. This own wery lage in PDF on English. It's consist from 100sh.
DIGITAL LASER COPIER
DIGITAL MULTIFUNCTIONAL
SYSTEM
OPERATION MANUAL
Page
INTRODUCTION
SETTING UP THE UNIT
LOADING PAPER
MAKING COPIES
SPECIAL FUNCTIONS
MAINTENANCE
TROUBLESHOOTING
THE UNIT
14
46
52
57
61
68
INSTALLING THE
SOFTWARE (AL-1641CS)
19
APPENDIX
AL-1631
AL-1641CS
MODEL
AL-1631/AL-1641CS
FOR YOUR PROTECTION...
To aid in reporting this unit in case of loss or theft, please record below the model number
and serial number located on the back of the unit. We also suggest you record all the
information listed and retain for future reference.
MODEL NUMBER SERIAL NUMBER
DATE OF PURCHASE
Dealer
Address City
State Zip Telephone
Service Station
Address City
State Zip Telephone
To obtain service, or to obtain product literature, accessories, or
supplies,
please call 1-(630)378-3590 in the USA
or 905-568-7140 in Canada.
For customer assistance, please visit http://www.sharpusa.com/
(for USA) or http://www.sharp.ca/ (for Canada) on the World Wide Web
or call 1-(630)378-3590 (for USA).
Do not make copies of anything which is prohibited from copying by law. The
following items are normally prohibited from copying by national law. Other
items may be prohibited by local law.
Money Stamps Bonds Stocks Bank drafts
Checks Passports Driver's licenses
CAUTIONS
Caution label on the unit
The label ( ) in the fusing area of the unit indicates the following:
: Caution, risk of danger
: Caution, hot surface
Cautions on using
Follow the cautions below when using this unit.
Warning:
• The fusing area is hot. Exercise care in this area when removing misfed paper.
• Do not look directly at the light source. Doing so may damage your eyes.
• Do not switch the unit rapidly on and off. After turning the unit off, wait 10 to 15
seconds before turning it back on.
• Unit power must be turned off before installing any supplies.
Caution:
• Place the unit on a firm, level surface.
• Do not install the unit in a humid or dusty location.
• When the unit is not used for a long time, for example for consecutive holidays,
turn the power switch off and remove the power cord from the outlet.
• When moving the unit, be sure to turn the power switch off and remove the power
• Do not cover the unit with a dust cover, cloth or plastic film while the power is on.
Doing so may prevent heat radiation, damaging the unit.
• Use of controls or adjustments or performance of procedures other than those
specified herein may result in hazardous radiation exposure.
• The socket-outlet shall be installed near the unit and shall be easily accessible.
Important points when selecting an installation site
Do not install your unit in areas that are:
• damp, humid, or very dusty
• exposed to direct sunlight
• poorly ventilated
• subject to extreme temperature or humidity changes, e.g., near an air conditioner
or heater.
Be sure to allow the required space around the
machine for servicing and proper ventilation. 8" (20cm)
4"
(10cm)
4"
(10cm)
Cautions on handling
Be careful in handling the unit as follows to maintain the performance of this unit.
Do not drop the unit, subject it to shock or strike it against any object.
Do not expose the drum cartridge to direct sunlight.
• Doing so will damage the surface (green portion) of the drum cartridge, causing
smudges on copies.
Store spare supplies such as drum cartridges and TD cartridges in a dark
place without removing from the package before use.
• If they are exposed to direct sunlight, smudges on copies may result.
Do not touch the surface (green portion) of the drum cartridge.
• Doing so will damage the surface of the cartridge, causing smudges on copies.
Trademark acknowledgements
• Microsoft® Windows® operating system is a trademark or copyright of Microsoft
Corporation in the U.S.A. and other countries.
• Windows® 95, Windows® 98, Windows® Me, Windows NT® 4.0, Windows® 2000,
and Windows® XP are trademarks or copyrights of Microsoft Corporation in the
• IBM and PC/AT are trademarks of International Business Machines Corporation.
• Acrobat® Reader Copyright© 1987- 2002 Adobe Systems Incorporated. All rights
reserved. Adobe, the Adobe logo, Acrobat, and the Acrobat logo are trademarks of
• All other trademarks and copyrights are the property of their respective owners.
For users in the USA
For users in Canada
As an ENERGY STAR® Partner, SHARP has determined that
this product meets the ENERGY STAR® guidelines for energy
efficiency.
Safety precautions:
This Digital Copier is rated Class 1 and complies with 21 CFR 1040.10 and
1040.11 of the CDRH standards. This means that the unit does not produce
hazardous laser radiation. For your safety, observe the precautions below.
• Do not remove the cabinet, operation panel or any other covers.
• The unit’s exterior covers contain several safety interlock switches. Do not
bypass any safety interlock by inserting wedges or other items into switch slots.
A small amount of ozone is produced within the unit during operation. The
emission leve////////.................................
Sorry? the file so lage?
This all that me to manage to place for issue.... file very big. I can you to send the электонной mail or send черех exchange file. Only I have a no right simply to return the instruction service, this instruction for repair of the faults I work in company on repair produkciisharp her(its) cost E20 evro. My address goodgold@inbox.ru write and we agree, I ready to send immediately. Respectfully yours, Sergey
Sep 08, 2009 | Sharp AL 1631 Copier
Sunbeam Ultrasonic Humidifier, model: 697-6
Located My Manual:
Hope this helps!
1. Remove tank from base. Turn upside down and unscrew filling cap. Fill tank with clean, cool, distilled, or tap water. Water temp should NEVER be too hot or too cold. Return tank to base and let sit for a few minutes. Be sure the filling cap of the tank is tightened firmly.
2. Plug power cord into a 110-120V AC wall outlet only. Turn power switch to "on" position. Power light will illuminate. Turn mist nozzle until desired level is being released. Aim nozzle away from furniture and walls.
3. Always turn humidifier off when water runs* out. Unit will continue to operate when tank is empty.
*Humidifier will run up to 12 hrs on low; 6 hrs on high.
DO NOT LET WATER SIT IN TANK FOR LONG. THIS CAN ENCOURAGE BACTERIAL GROWTH.
Place unit on level surface away from direct sunlight.
DO NOT ADD MEDICATION OF ANY TYPE INTO THE NOZZLE, BASE, OR WATER TANK.
ALWAYS LEAVE ROOM DOOR PARTLY OPEN. DO NOT MOVE, TILT, OR EMPTY WHILE OPERATING.
Mild bleach and water solution for cleaning, never detergent.
Clean every 3rd day during use. Clean after long storage
Humidity varies from room to room. Aim for 30 - 50% relative humidity. If windows/ walls fog or frost, reduce mist intensity. If room too humid, ventilate by opening door or window; adjust mist intensity.
Sep 22, 2008 | Sunbeam Ultrasonic Humidifier
Running the camcorder continuously
Those camcorders are not intended to be surveillance cameras. There are however, steps you can take to ensure maximum longevity. * Keep the unit dry (avoid rain, inclement weather, etc.) * Ventilate the unit, i.e. make sure there is plenty of free air around the unit for cooling. * Shield from direct sunlight if possible * Avoid extremes of temperature and humidity.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
634 people viewed this tip
Top Jeep Audio Players & Recorders Experts
Thomas Perkins
Thomas Perkins
Tom Chichester
Bill Boyd
Are you a Jeep Audio Player and Recorder Expert? Answer questions, earn points and help others
