Tip & How-To about Jeep KNG36-JXLWBC AM/FM/Weather Radio
USING THE WEATHER BAND STATION 1. FOR WEATHER STATIONS, CLICK THE WEAIHER BAND/AM/FM (13) TO ?WB?. 2. TUNE FOR THE WEATHER STATIONS BY THE TUNING (14).
Jeep KNG36-JXLWBC AM/FM/Weather Radio Logo
preseting radio stations so i don't have to use the tuning dial everytime
Most radios let you set them like this - select bandwidth FM/AM then tune to a favourite station, find the row of numbered buttons under digital display (usually 1 - 5) then press and hold button 1 for a few seconds, the station will be set to button 1, so to speak. Repeat tuning to another station then press button 2, etc...some radios have up to 15 slots per band. How many stations do you listen to....
To recall station 1, press button 1 ..button 2.......... Red.
Apr 05, 2014 | 1997 Isuzu Hombre
how do i program the radio
Click below for the manual.
manual
1 Select the radio band and tune in a desired radio
station you wish to store in the preset memory.
2 Press (PRESET).
The Preset screen is displayed.
3 Rotate the Double Action encoder to select the
preset number.
4 Press and hold /ENTER for at least 2 seconds.
The selected station is stored.
The display shows the band, preset number and station
frequency memorized.
A total of 18 stations can be stored in the preset memory (6 stations
for each band; FM1, FM2 and AM).
If you store a station in a preset memory which already has a station,
the current station will be cleared and replaced with the new station.
Press in the outer ring and rotate the Double Action encoder to the
left or right on the Preset screen, you can switch the Preset screen of
another band.
FM-1 FM-2 AM FM-1
You can also change the desired radio band by pressing BAND.
Hope this helps.
Zeppelinx12
Feb 25, 2011 | Alpine iDAX305 MP3USB Car Radio Car CD...
How do I preset the tuner for radio stations. I've never had a problem doing this with any other stereo. But what I think should work isn't!
Not very specific. Do you have the manual?
The following is from a VSX-03TXH manual. It ain't pretty but it may help.
I'm posting it in multiple parts due to space contraints.
37
Chapter 6:
Using the tuner
Listening to the radio
The following steps show you how to tune in to FM and
AM radio broadcasts using the automatic (search) and
manual (step) tuning functions. If you already know the
frequency of the station you want, see Tuning directly to a
station below. Once you are tuned to a station you can
memorize the frequency for recall later-see Saving
station presets below for more on how to do this.
1 Press the FM/AM button to select the tuner.
2 Use the FM/AM button to change the band (FM or
AM), if necessary.
Each press switches the band between FM and AM.
3 Tune to a station.
There are three ways to do this:
Automatic tuning
To search for stations in the currently selected band,
press and hold TUNE ?©/?? for about a second. The
receiver will start searching for the next station,
stopping when it has found one. Repeat to search for
other stations.
Manual tuning
To change the frequency one step at a time, press
TUNE ?©/??.
High speed tuning
Press and hold TUNE ?©/?? for high speed tuning.
Release the button at the frequency you want.
Improving FM stereo sound
If the TUNED or STEREO indicators don't light when
tuning to an FM station because the signal is weak, press
the MPX button to switch the receiver into mono
reception mode. This should improve the sound quality
and allow you to enjoy the broadcast.
Using Neural THX
This feature uses Neural Surround™, THX® technology to
achieve optimal surround sound from FM radio.
• While listening to FM radio, press AUTO/DIRECT for
Neural THX listening.
Dec 23, 2010 | Pioneer VSX-07TX Receiver
sony walkman fx281 says hold when I push AM or FM button How do I turn on radio?
Srt HOLD switch to Off position as shwon in below image so Radio will start work.
Thanks.
Feb 05, 2010 | Sony Walkman WM-FX281 Personal Cassette...
570 people viewed this tip
Top Jeep Audio Players & Recorders Experts
Thomas Perkins
Thomas Perkins
Tom Chichester
Duff Howell
Are you a Jeep Audio Player and Recorder Expert? Answer questions, earn points and help others
