Tip & How-To about Jeep KNG36-JXLWBC AM/FM/Weather Radio
LANTERN OPERATION 1. PUSH THE LANTFRN/FLASHSLIGHT/OFF (11) TO ?LANTERN 1+2? OR ?LANTERN I?. THE LANTERN WILL BE TURNED ON. 2. PUSH THE LANTERN/FLASHLIGHT/OFF (11) TO ?FLASHLIGHT? TO TURN ON I?HE FRONT LIGHT. 3. PUSH THE LANTERN/FLASHLIGHT/OFF (11) TO ?OFF? THEN BOTII LANTERN AND FLASHLIGHT WILL BE TURNED OFF. 4. PUSH THE BLINKER/SIREN/OFF (12) TO ?BLINKER? AND THE FLASH LIGHT (10) WILL BLINK. 5. PUSH THE BLINKER/SIREN/OFF (12) TO ?SIREN? AND THE SIREN WILL BE TURNED ON. 6. PUSH THE BLINKER/SIREN/OFF (12) TO ?OFF? AND BOTH THE FLASH LIGHT (10) AND THE SIREN WILL BE TURNED OFF. 7. PULL OUT THE LANTERN (16) AND ADJUST THE LANTERN ANGLE.
Jeep KNG36-JXLWBC AM/FM/Weather Radio Logo
Why doesn't lantern turn on when not plugged in?
I have a rechargeable spotlight and the directions specifically say not to turn it on while connected to the charger.
Mar 10, 2016 | Coleman Cpx 6 Rechargeable Power Cartridge...
how to connect a spring pole 6v battery
Inside the case of the light, there will be 1 wire with a tapered notched connector. Take the connector with the low end of the taper and push it into the negative (-) spring (in between the coils ) of the battery. The spring will wedge the connector it one of the notches and will hold it securely. Reattach the lense carefully seating the end of the bulb onto the positive (+) spring of the battery.
May 25, 2014 | Energizer Eveready Utility Lantern Uses 6V...
1990 flhs turns over but wont start
Hi Anonymous, and the usual suspects are:
1. Fuel tank empty
2. Fuel supply valve turned off.
3. Fouled spark plugs.
4. Engine flooded with gasoline as a result of over use of enrichner.
5. Fuel valve or filter clogged.
6. Vacuum hose to automatic fuel supply valve disconnected, leaking, or pinched.
7. Discharged battery, loose or broken battery connections.
8. Loose wire connection at coil, battery or plug between ignition sensor and module.
9. Spark plug cables in bad condition and shorting, spark plug cable connections loose,
or cables connected to wrong cylinders.
10. Ignition timing incorrect due to faulty ignition coil, ignition module, or sensors " Manifold Absolute Pressure" "Camshaft Position Sensor" "Crank Position Sensor" "Brake Apply Sensor
11. Engine lubricant to heavy ( winter operation )
12. Sticking or damaged valves or push rod wrong length.
13. Primary cam sproket spline sheared or missing spacer.
Jan 28, 2014 | Harley Davidson Motorcycles
1989 1200 xl sportster some times starts some times wont
1. Fuel tank empty
Good luck
Jan 24, 2014 | Harley Davidson Motorcycles
454 people viewed this tip
Top Jeep Audio Players & Recorders Experts
Thomas Perkins
Thomas Perkins
Tom Chichester
Bill Boyd
Are you a Jeep Audio Player and Recorder Expert? Answer questions, earn points and help others
