Tip & How-To about Jeep KNG36-JXLWBC AM/FM/Weather Radio
BATTERY INSTALLATION FOR CLOCK : OPEN THE BATTERY COMPARTMENT DOOR. DRIVE THE SCREW OUT AND INSERT 1 NEW UM4 1.5V BATTERY INTO THE COMPARTMENT FOLLOWING THE POLARITIES AS INDICATED. DRIVE BACK THE SCREW TO LOCK THE BATTERY COMPARTMENT. FOR RADIO: INSERT 4 NEW ?SIZE D? 1.5V BATTERIES (FOR RADIO) FOLLOWING THE POLARITIES AS INDICATED.
Jeep KNG36-JXLWBC AM/FM/Weather Radio Logo
i need instructions for my timex clock
Hello
Here are the instructions for your clock-radio.
Installation
1* Remove unit and all packing materials from the carton. You should save packing
materials in case unit needs to be returned for service. If you do not wish to save the
materials, please dispose of them properly.
2* Place the unit on a stable, level surface, close to an AC outlet, out of direct sunlight,
and away from sources of dust, dirt, heat, water, moisture, vibration, or magnetic fields.
3* After installing the batteries (see below) and reading the Maintenance notes, plug the
AC cord into an outlet.
"Sure Alarm" Battery Backup Installation
It is strongly recommended that 2 "AA" batteries be installed into the unit, as directed below,
in order to activate this product's "Sure Alarm" Battery Backup feature. (The model should
come with two batteries already installed.) In the event that the AC power cord is disconnected
or a power failure or other interruption occurs, the "Sure Alarm" Battery Backup will maintain
clock and alarm settings for the life of the battery, ensuring that the alarm (buzzer only) will
sound at the set time. During any interruptions the time and alarm settings will be saved
and automatically restored when AC power is again active.
1* Gently turn the unit over and remove the battery
compartment door.
2. Install 2 "AA" batteries (alkaline is recommended for
longer life), while making sure that the + and - ends
match up with those inside the battery compartment.
3* Slide the battery compartment door back on, making
sure the door locks into place, and gently return the
unit to its upright position.
Aug 19, 2011 | Timex Auto-Set Dual Alarm Digital Clock...
The alarm display in the lower right corner on model #RC40-A keeps blinking and will not stop. This happens with both wake 1 and wake 2 options. I fixed it once by unplugging the unit but it this did not work the second time. Is there another solution?
Hello
Just reinstall the battries and adjust the time once again.
Battery back-up operation
* This clock radio is equipped with
a memory holding system that can
be powered with 2 "AA" batteries
(included). The power failure
protection circuit will not operate
unless battery is installed.
* When normal household power
is interrupted, or AC line cord
is unplugged, the batteries will
power the clock radio to keep
track of time and alarm settings
programmed into memory.
* When the battery backup functions,
the digital display will not light,
however, the function of alarm
still occurs during the power
interruption if remaining battery
power is adequate.
* Normal operation will resume after
AC power is restored so you will not
have to reset the time or the alarm
To install batteries:
1* Remove battery compartment door
(located at the bottom of the radio)
by applying thumb pressure to the
tab on battery door and then lift
the door out and off the cabinet
2* Insert 2 AA batteries (included).
3* Replace the compartment door
Replace batteries every year.
Power is fed to the unit even
when it is not functioning. To
cut the power supply off, the
power cable must be unplugged
OK.
Jul 10, 2011 | RCA Rc40 Clock Radio
How i can mount a new battery cover on Olympus SP-560 UZ
i just purchased a new cover for $33 from uscamera. part#omp vg4293. You will need a jewlers philips screw driver. Make sure you lay out screws where they came out. They're different. Looking at the bottom,Remove 1 screw under battery door. Two screws on bottom my mount. Open little door on left for mem card and remove 2 screws. Open little door on right side where cable goes, remove 2 screws. Then gently on end wher door goes, pull back cover back just enough to remove old door and reinstall new door. Press back together and install screws.
Jun 18, 2010 | Olympus SP-560 UZ Digital Camera
Is it difficult to install a new RAM on the e-machine M5305 series laptop?
No, not really but you have to be careful about electronic static. A eletrostatic strap or grounding must be observed before entering the laptop body.
The batteries are located in a compartment on the bottom of the laptop.
there are maybe 1 or 2 screws holding the battery compartment secure.
Proper placement of the new ram is essential to the the installation .
moz-screenshot-2.pngmemory
To remove and install a memory module:
1. Power off your notebook and close the display. Disconnect all cables,
including the AC power adapter, modem, and network cables.
2. Place your notebook upside down on a stable work surface.
3. Remove the memory compartment cover screw and cover.
Before performing any of the procedures in this section,
follow industry-standard practices for preventing
electrostatic discharge. See the Warning note.
To prevent damage to your notebook, remove the installed
battery pack before replacing this component.
this is the instruction from the user manual:
To remove an existing memory module, gently press outward on the
retaining clips on both sides of the memory module 1 until the memory
module is released and tilts upward. Then, pull the module out of the slot 2.
getting started
60
5. To insert a new memory module, hold the memory module at a 45-degree
angle and insert it into the empty memory slot 1.
Gently press down on the module until the retaining clips click into place 2.
6. Replace the memory compartment cover and retaining screw. Insert the
battery pack and reconnect your cables.
The memory module is keyed so that it can be inserted in
only one direction. If the module does not slide in easily,
verify that the notch in the module lines up with the tab in
the memory slot.
Apr 06, 2010 | E-Machines M5305 Notebook
replaced batteries= how to set clock -time, etc/
• Twist and lift open the battery compartment cover at the back of the clock and insert 1 fresh AA, LR6 1.5 volt ALKALINE battery according to the polarity marked on the case.
• Press time zone button to select a time zone.
• Replace the battery compartment cover.
THAT’S IT! During the night your clock will automatically set itself.
It will do it itself just need to wait thats all
Apr 21, 2008 | La Crosse Radio Controlled Atomic Clock
390 people viewed this tip
Top Jeep Audio Players & Recorders Experts
Thomas Perkins
Thomas Perkins
Tom Chichester
Bill Boyd
Are you a Jeep Audio Player and Recorder Expert? Answer questions, earn points and help others
