Tip & How-To about Jeep KNG36-JXLWBC AM/FM/Weather Radio
Flashlight Battery and Bulb Installation and...
FLASHLIGHT
BATTERY INSTALLATION FOR TORCH:
Open the Torch Battery Door located on the bottom of the Torch.
Insert 4 “A A” (1 .5V UM-3) (not included) batteries (alkaline
batteries are recommended) into the torch compartment. Be sure
the polarity (+ and
-) matches, as marked inside the battery
compartment.
FLASHLIGHT:
Slide the Torch Function Switch to the “FLASH” position, the Torch will light. To turn off, slide the Torch Function Switch to the “OFF’ position.
FLASH/BLINK FUNCTION:
Slide the Torch Function Switch to “FLASH/BLINK” position, tha Torch will light and thc bulbs on both sides of Torch will blink.
BULB REPLACEMENT:
Rotate the Torch Cover anticlockwise to hear “click”
then p
ull out the cover, remove the old bulb. Then pull
out the torch cup, remove the blinker’s
old bulbs and
reinstall new bulbs. Replace the torch cup, then reinstall
a new bulb. Replace the Torch Cover.
Jeep KNG36-JXLWBC AM/FM/Weather Radio Logo
put batteries in a highland series 150
I'm not familiar with this particular torch but similar torches use an adaptor such as one depicted below to enable AAA batteries to be used where the primary battery is either a 18650 battery or two CR123 batteries in series. I hope this helps.
Sep 21, 2014 | LifeGear Life Gear Highland Series 150...
F-S1 battery life is too short
The Torch's battery life is notoriously short. I would suggest you purchase an extended battery for the phone.
There's a few different options available for you:
You may purchase an extended battery, but it requires a different backing.
Or you can purchase another battery and swap them out.
Extended:
http://www.buy.com/prod/black-for-blackberry-torch-9800-extended-battery-door/q/sellerid/24501607/loc/111/219781558.html
Another battery:
http://www.google.com/products/catalog?hl=en&q=oem+torch+battery&bav=on.2,or.r_gc.r_pw.&um=1&ie=UTF-8&cid=16050621926286596060&sa=X&ei=j8iKTcTKDIb2gAeUkMjKDQ&ved=0CCkQ8wIwAg#
Mar 24, 2011 | RIM Blackberry F-S1 Battery for Blackberry...
how do you change batteries stanley 3 in 1 tripod led flashlight
The unit is 3 individual flash lights. Pull one of the flashlights by the head (the light part) it will come out easily once you know what you are doing. The other two may be pulled out in the same manner. The bottom will then unscrew where you will be able to replace the AA batteries. Each flashlight will then go back into place very easily. Hint...test each individual flashlight before putting back together to make sure you have your batteries in the proper place and that they are useable batteries.
Dec 08, 2010 | Stanley 3in1 Tripod LED Flashlight 95155
how do i open eveready dolphin torch for battery
You need to twist the black bulb end off in the direction of the arrow labeled open. The best way I found was to place the yellow end between my legs to hold it in place.
Sep 23, 2010 | Camping, Backpacking & Hiking
384 people viewed this tip
Top Jeep Audio Players & Recorders Experts
Thomas Perkins
Thomas Perkins
Tom Chichester
Bill Boyd
Are you a Jeep Audio Player and Recorder Expert? Answer questions, earn points and help others
