Tip & How-To about Jeep KNG36-JXLWBC AM/FM/Weather Radio
Parts Callout
INSTRUCTION MANUAL PARTS LOCATOR
1. ANTENNA
2. BATTERY COMPARTMENT
3. CARRYING HANDLE
4. COMPASS
5. SPEAKER
6. LCD CLOCK DISPLAY
7. BACK LIGHT (CLOCK)
8. MODE
9. SET
10. FLASHLIGHT
11. LANTERN / FLASHLIGHT / OFF
12. BLINKER I SIREN / OFF
13. WEATHER BAND/AM/FM SELECTOR
14. TUNING
15. VOLUME ON/OFF
16. LANTERN
Jeep KNG36-JXLWBC AM/FM/Weather Radio Logo
where has the replacement battery CR1620 must be placed?
1) Open the main battery compartment
2) Remove the battery tray
3) Inside the battery compartment directly behind the LCD screen there is a small cover about the same size as the CR1620.
4) Remove the cover
5) Replace the battery
6) Replace the cover
7) Replace the battery tray
Jul 20, 2012 | Polaroid Battery Grip for Canon EOS-7D...
Anyone have the 2001 VW Golf speaker wire colors?
If your Golf is the premium sound model here is the list:
2001 Volkswagen Golf Car Radio Wiring Schematic for Monsoon Audio
Car Radio Battery Constant 12v+ Wire: Plug #3, Pin #7
Car Radio Accessory Switched 12v+ Wire: Plug #3, Pin #4
Car Radio Ground Wire: Plug #3, Pin #8
Car Radio Illumination Wire: Plug #3, Pin #6
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Plug #2, Pin #5
Left Front Speaker Negative Wire (-): Plug #2, Pin #6
Right Front Speaker Positive Wire (+): Plug #2, Pin #3
Right Front Speaker Negative Wire (-): Plug #2, Pin #4
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Plug #2, Pin #7
Left Rear Speaker Negative Wire (-): Plug #2, Pin #8
Right Rear Speaker Positive Wire (+): Plug #2, Pin #1
Right Rear Speaker Negative Wire (-): Plug #2, Pin #2
Signal for Anti-Theft Alarm System Wire: Plug #3, Pin #1
Data Link Connector (DLC) K-Wire: Plug #3, Pin #3
Battery Supply Constant 12v+ Wire for Anti-Theft System (SAFE): Plug #3, Pin #5
CD Changer Data In Wire: Plug #1, Pin #13
CD Changer Data Out Wire: Plug #1, Pin #14
CD Changer Clock Wire: Plug #1, Pin #15
CD Changer Constant Battery 12v+ Wire: Plug #1, Pin #16
CD Changer Control Signal Wire: Plug #1, Pin #17
CD Changer Ground Wire: Plug #1, Pin #18
CD Changer Left Line Out Wire: Plug #1, Pin #19
CD Changer Right Line Out Wire: Plug #1, Pin #20
May 18, 2010 | Car Audio & Video
Changing the time
you can go to http://www2.oregonscientific.com/assets/manuals2/bar338pa.pdf to see or print the user's manual.
If you don't want to get the manual, here's what you do to fix it. . . . .
*note: you need to do this anytime you change the batteries.
1) open the battery cover
2) on the left side you'll see 3 little buttons labeled a)zone, b)C/F c)reset
3) push the reset
4)push the zone button until your time zone is highlighted on the front display
5) look at the front display & if you see a blinking "radio signal" icon at upper left of time numerals
don't do anything else. The time, date, etc. will automatically synchronize your clock with the US Atomic Clock. This could take up to 10 minutes. As long as the "radio signal" icon is blinking, it's working on it. When the icon doesnt' blink, it's set. Cool, huh?
6) if the area you live in can't receive the signal from the Atomic Clock, instead of a blinking "radio signal", you'll see just a bare antennae. Since you probably set your clock manually, that's what it shows now before you do anything.
7) after you push reset & set the time zone do NOT touch any other buttons to set anything!!! (I know it's difficult to leave things alone, but just sit on your hands). Pushing the "clock" button or the up & down arrows will stop the radio signal & change to manual functions. Look at the signal icon mentioned in 5) and 6) above. If you only have the bare antennae icon. . . . . go ahead & set the time/date yourself. You have no signal.
Enjoy your clock!
debkresh
Jan 25, 2009 | Oregon Scientific FM Weather Projection...
lost manual for a timex t307s
Setting the Alarm 1 for AM/FM Radio
1. Press and hold the 2 Radio Alarm 1 Button. The display will flash and the Radio Alarm Indicator will appear. If
you do not begin setting the time within ten seconds of pressing the button, the display will stop flashing and you will
need to press the 2 Radio Alarm 1 Button again.
2. While the display flashes, press the 1 Reverse and 6 Forward Buttons to set the wake time. Hold a button for a few
seconds to set the time rapidly. Be sure to set the correct AM/PM time, as shown by the PM Indicator.
3. After setting the radio alarm time, while the display is still flashing you will need to select the station. First, press the
L Mode/DST Button to select a radio frequency. Next, select a station using the M Memory Set 1-6 Buttons. For
more information on programming radio stations into memory, see the Programming Radio Station Settings section of
this manual. Rotate the O Volume Thumbwheel to set the wake sound volume.
4. After setting the radio alarm wake time and sound, you will need to select the 7-5-2 setting. The 7-5-2 setting lets you
set the alarm for a full week, weekdays only, or the weekend. Before setting the alarm, be sure that the correct date
is set, as shown in the “Auto-Set” and Manual Time and Date Settings section of the manual. While the display is still
flashing, press the 9 Date/7-5-2 Button until the desired setting is shown.
5. After you have set the radio alarm wake time, sound, and 7-5-2 setting, press the 4 Enter Button. The Radio Alarm
Indicator
will appear on the display, showing that the radio alarm has been set.
Setting Alarm 2 for Nature Sounds/Buzzer
1. Press and hold the 7 Nature Sounds/Buzzer Alarm 2 Button until the Alarm 2 settings and Sounds Alarm
Indicator appear on the display.
2. Press the 1 Reverse or 6 Forward Button to set the Alarm 2 time.
3. Use the L Mode/DST Button to select a nature sound or the buzzer to wake to. There is a choice of five sounds:
Sound #1: Ocean Surf
Sound #2: Birds
Sound #3: Brook
Sound #4: Wind Chimes
buz: Buzzer
4. See Note #4 in the Setting Alarm 1 section for instructions on setting the 7-5-2 alarm setting for Alarm 2.
5. After you have programmed the Alarm 2 settings, press the 4 Enter Button or wait ten seconds to return to the clock
display. The Sounds Alarm Indicator will appear on the display, showing that the alarm is set.
Nov 18, 2008 | Timex (T307S) Clock Radio
452 people viewed this tip
Top Jeep Audio Players & Recorders Experts
Thomas Perkins
Thomas Perkins
Tom Chichester
Bill Boyd
Are you a Jeep Audio Player and Recorder Expert? Answer questions, earn points and help others
