Tip & How-To about Cuisinart ICAPP-4
Other Notes on The ICAPP-4
Notes
- the whole process of making iced cappuccinos from the time you press the ON button until the unit shuts off automatically takes about 10 minutes
- once you press the ON button, the unit does not make a sound for several minutes – be patient
- remember to position the carafe so that the handle touches the right front of the unit, and the spout touches the left front of the unit – critical for smooth milk/espresso admixture/ramping
- clean the removable parts after every use to avoid damaging your ICAPP
- once a month, run a decalcification process – simply pour 2 tbsp vinegar on a damp cloth, wipe the water reservoir, and then run a cycle of water – ostensibly, the vinegar residue should be enough vinegar for the decalcification process – newer Cuisinart coffee and espresso makers often recommend a specific portion of vinegar and water – not so with this unit
- several of the instruction book’s recipes call for adding sugar or flavored syrup – remember to add them AFTER the cappuccino is made, directly into the carafe – do not pour sugary ingredients into the inside of the machine, or you will have a sticky mess on your hands
- parts are no longer available for this model through the company directly; all units are out-of-warranty because of the age of the product; but several of the cappuccino and espresso recipes are still available at Cuisinart’s website
- if you are missing parts for the unit, I would buy one – broken or otherwise – from an independent seller, eBay, etc who has the part you need
Cuisinart ICAPP-4 Logo
Model GFSF6KEXWW FRENCH DOORS WITH FREEZER ON BOTTOM AND ICE MAKER IN DRAWER. TEMP READINGS SAY "OF"
Hello & Welcome to FixYa
The error should read O FF if that is the error then it means that the unit is in demo mode. To remove error code, refrigerator door must be open. Press and hold Refrigerator and Ice Plus button simultaneously for 5 to 10 seconds or until the display changes. This is NOT the Er FF Error Code. Please get back to me if you have any other questions.
Kevin
Sep 19, 2011 | GE Refrigerators
I need instructions for a Cuisinart Iced Cappuccino Maker
I have a PDF of the user manual if you want me to e-mail it to you. In the meantime, here is my Wiki Manual (BTW, pagan, the machine does make hot espresso or cappucino, but it doesn't froth per se like a regular espresso machine - it just heats the milk internally and dumps it into the espresso):
General Directions for Making Iced Cappuccinos
- Place carafe on top of drip/tray grate with handle touching right front of ICAPP – the ice fill lines should be visible when looking at front of unit
- Turn “milk knob” to OPEN position, and open lid of ICAPP
- Remove milk container, espresso collector, espresso spinner cup and cover
- Put espresso collector back in place with two plastic teeth facing front of machine
- There is a stepped fill line inside water reservoir that measures off 1,2, and 4 cups
- Fill water reservoir with either 1,2 or 4 fill line cups – do not overfill to avoid damaging the electronics
- Add espresso grounds to espresso spinner cup
- Line up teeth of spinner cup cover with spinner cup so that the cover locks into place
- Fill milk reservoir with 3 oz of milk per cup of iced cappuccino that you plan to make – there is a fill line that measures off 2 cups or 4 cups
- Fill carafe with either 2 cups worth of ice or 4 cups, depending on how much iced cappuccino you plan to make
- Press down on lid and turn milk knob to HEAT postion
- Turn ICAPP on using the ON/OFF button – it will begin to heat – takes about 5-6 minutes (HEAT light will stay on during this process – doesn’t make noise or steam for several minutes)
- When READY light turns green, turn the milk knob to the DISPENSE MILK position – your espresso and milk will start dispensing
- Unit turns itself off automatically when ready – takes several minutes
Feb 26, 2009 | Cuisinart ICAPP-4
NEED DIRECTIONS For Model ICAPP-4
I can answer just about any question you have on the unit - I wasn't able to find the manual online, but I would be more than happy to scan and e-mail you my copy of the original manual. In the meantime, here is my basic Wiki Manual:
Since I am not well-versed in the copyright laws regarding reprinting copies of standard user’s manuals online, I am writing this Wiki Manual for the ICAPP-4. My unit is 12 years old (in 2009) and continues to run strong through two different owners.
-Tha Mp3 Doctor
Feb 25, 2009 | Cuisinart Coffee Makers & Espresso...
honeywell oil radiator
Press the *power button* once to start the heater on high power, continuous run. If left at this setting, the unit will run continuously on high power (1500 watts, 12.5 amps) and will not shut off until the unit is manually turned off.
Press the *power button* again, to change to low power, continuous run, (900 watts, 7.5 amps) and will not shut off until the unit is manually turned off.
Set temperature:
Press the temp/timer button until the temperature icon blinks. Use the up and down arrows to set the desired temperature.
The temperature icon will stop blinking and the current room temperature will reappear after the desired temperature is set.
The heater will turn off and on to achieve the desired temperature.
Set timer: (auto off)
Press the timer/timer button until the timer icon blinks. The hour display will appear. The auto off icon will also appear.
Use the up and down arrow buttons to set the heater operation time between 1 and 10 hours. This function will activate once the timer icon stops blinking. The heater will automatically turn off whn the times runs out.
Set timer: (auto on)
Press the temp/timer button until the timer icon blinks. The hour display will appear. The auto on icon will also appear.
Use the up and down arrow buttons to set the heater start time between 1 and 10 hours. This function will activate once the timer icon stops blinking.
The heater will automatically turn on when time expires.
Hope this helps!
Sep 24, 2007 | Honeywell /KAZ HOME ENVIRONME HZ-705 7Fin...
1,169 people viewed this tip
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
