Tip & How-To about Gateway 450ROG Notebook
Intel wireless drivers for Gateway 450ROG
Recently ran into an issue where someone did not have all the original materials for their laptop. One of the issues was the wireless NIC acting up. The drivers were kind of a pita to locate so I figured I'd post a link here to the Intel drivers.
http://support.mpccorp.com/apps/disclaimer.asp?FilePath=/support/gateway/9525415.exe
Gateway 450ROG Notebook Logo
download nic
If you get a 'Limited connectivity" on you wireless connection on your laptop, it means that the wireless card on your laptop probably did not get an IP address from the wireless router.
To fix this problem, right click on the wireless icon on the Task bar and then click Repair.
This will force the wireless router to issue a IP address to the wireless card on the laptop.
Aug 31, 2012 | Dell OptiPlex GX150 PC Desktop
can someone help mee?? I just got a used laptop
Hi! some laptop have a built in wireless network card.. some dont have.. check first if the laptop have a built-in wireless nic. if there is one.. some of this wireless nic use the built in software so that you can connect wirelessly. you can just turn off that software and use the windows xp wireless zero config.. to turn on the windows xp wireless zero config, sometimes there is an option if you turn of the software for the wireless nic but if there is no option, you can click on start and then select run and from the box, type services.msc and it will show you all the services for the computer and scroll down to the button and you will see wireless zero config and its off or disable just right click and it will give you the option and enable it.. this will connect you wirelessly without any problem..
Jul 12, 2009 | Belkin (F5D5231-4) Router
nic card issues?
Do you have any 2.4MHz cordless phones in the house or is the computer near a microwave? those two items can cause interference. You can go to Dell.com, go to support then download drivers/software, enter in your service tag is best if you know it? find the network card driver and download it. You can find out which NIC card you have by going to my computer, system, then device manager and right click on the NIC, then properties, it will tell you what card you have.
Apr 08, 2009 | Dell Ethernet Card Network Adapter
Wireless connection works but no plug in connection
The wired nic in your laptop will have a separate ip address than your wireless nic. I suspect you either have the router not set to hand out ip addresses, the info it is handing out is wrong, or you may have a static ip set. Did you ever have the laptop working on the wired nic?
Try disabling the wireless connection, plug up the cat 5 cable, open a dos prompt and type;
ipconfig /all
Notice the information. Now unplug the cable, enable the wireless connection and do the same for the wireless nic. The ip address should be different, but everything else should be the same. Let me know what you find.
Oct 12, 2008 | D-Link AirPlus DI-524 Wireless Router
One card interfering with other connections
Have you checked to make sure the laptop wireless NIC isn't acting as an AP by mistake? That could explain both desktop and laptop connectivity issues. Just a thought.
Jan 29, 2008 | Linksys (WMP54GS) 802.11g/b Wireless...
2,747 people viewed this tip
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
