Tip & How-To about HP Scanjet G4050 Flatbed Scanner
Cleaning your inside scanner glass
Actually it's a very simple procedure!
Read this entire comment first...then start your procedures!
Disconnect the power cord, disconnect the USB cable, remove the top cover cable from the base by unscrewing the two plastic knobs, lift the top cover straight up. Place the top cover in a safe place.
On a clean, flat surface, turn the base upside down. On both ends you will find a total of four (4) black phillips head screws. Carefully unscrew these four screws and place aside. Carefully lift up the base and the top glass will separate from the base. Set the base aside. You have now exposed the inside glass for cleaning! It's that simple!!! Clean the glass by using a streak-free glass cleaner. Don't spray the glass, rather, lightly spray a clean soft lint free glass cleaning cloth, then wipe the glass. Don't press hard! Use good common sense1 There, you've now cleaned the interior glass. Reverse the procedure and you are finished. Wasn't that simple??
HP Scanjet G4050 Flatbed Scanner Logo
full waste tank canon i250
Hi Eli,
Canon i250 & i250 waste ink tank counter reset. by BSF (12/10/04 10:13 PM) +1 + / -
1. Disconnect printer from AC power (take out AC cord or power off your power strip). Disconnect USB PC cable from
printer.
2. Press and HOLD the POWER button (untill step 7).
3. Reconnect power cord (turn on power) to the printer.
4. The indicator should be green.
5. Press and release the RESUME button , the indicator should be orange.
6. Press and release the RESUME button again, the indicator should be green.
7. NOW Release POWER buttons.
8. NOW Connect the printer to PC (USB cable).
9. NOW...I opened "Printers" and saw that a "copy" of my printer (i250 or i350) had been made. Make that COPY your default printer and all should work...It did for me.
I must say...I went into the "GUTS" of the beast and cleaned out the PADS (they are actually vacuum pads that the INK is sucked through during a HEAD cleaning) a very messy undertaking.
Regards,
Sean
Sep 15, 2012 | Canon i250
I just refilled my ink cartridges and for some reason the printer still flashes no ink, any ideas?
  1. Press the On (c00636182.gif ) button to turn off the unit.
  2. Disconnect the power cord from the back of the unit.
  3. Connect the power cord to the back of the unit.
  4. Press the On (c00636182.gif ) button to turn on the unit.and hold it down 10 se
this are the usual procedure..some do it by actually power off ..disconnect power cord..hold down the button ..and connect power cord with the button pressed..and after it powers..release the button ..try it both way s..the issue is that you probably used refilled cartridges and it needs to reset the counters..
Jun 02, 2010 | HP DeskJet F380 All-In-One Printer
no dial tone
Have you replaced the phone cord to the wall? if not start here, if the base has not been dropped or wet, try resetting it.
Reset Procedure for Cordless Phones
Question:
What is the general reset procedure for cordless phones?
Answer:
1. Disconnect Battery from handset(s)
2. Disconnect Phone Cord from wall jack
3. Disconnect Phone cord from base unit
4. Disconnect AC adapter from wall outlet
5. Allow to sit for 30 min
6. Reconnect Phone Cord to base
7. Reconnect Phone cord to wall jack
8. Reconnect AC Adapter to wall outlet
9. Reconnect Battery to hanset until you click or feel the plug snap into place
10. Re-Register Handset by placing on main base in most instances.
<KEYWORDS="RESET, call,? can?t tone, dial no flashing, unavailable, range, of out working, not up, messed>
Hope this is of some help.
Ed
May 05, 2009 | Lands Phones
can use the phone it is only reading searching on the display.
Question:
Answer:
Apr 07, 2009 | Uniden DECT 6.0 Cordless Phone ID
2,760 people viewed this tip
Seeker5211
Seeker5211
