If the location of the condenser is above evaporator install oil trap to insure the oil return to the compressor. This is applicable to suction pipe only, and piping size should be in the standard size as per unit design.
The diagram is good and the tip is correct for smaller systems. For some applications, over 5 tons, the pipe size reduced at the evaporator and an auxiliary bypass for the trap may be needed. I had an evaporator installed above the compressor. Plus it was over 100 feet away. Because the distance and the ceiling height the suction and liquid lines ran over the evaporators and into the headers thus making the whole evaporator section a trap. I added and external trap with a bypass of smaller size to encourage oil droplets not a large amount of oil leaving the trap on start up. Just a word that there are exceptions to some piping rules. If in doubt consult then if it seems too easy consult as little more. GOOD tip though some people miss this trap and the tip all together. Then wonder why they have compressors going out every month or 2.
Hello, I have a Carrier Heating and Cooling, model 58PAV Upflow. When I turned it on and it operated...
(More)
Hello, I have a Carrier Heating and Cooling, model 58PAV Upflow. When I turned it on and it operated about serval cycle. I moved my hand close to the cover then I felt it was hot, but the burner did not start. Please help me to determine the problem and give me an idea how to resolve it. Thank you very much for your help. Please email me via chieu2002@yahoo.com Thanks
(More)
I have a weather 8000. It is not blowing heat. I am getting a 33 code. Ive replaced the filters and...
(More)
I have a weather 8000. It is not blowing heat. I am getting a 33 code. Ive replaced the filters and re-set the switch. still have code.
need owners manual for my unit or the wiring specs for it cant find the model number help on that...
(More)
need owners manual for my unit or the wiring specs for it cant find the model number help on that would be great too
