Home | All Products | 1 TB SATA II Hard Drive | Tips
Hard Drive Capacity NOT as Advertised
worldvet
By Guru worldvet
Rank: Guru
Rating: 91%, 816 votes
posted on Feb 12, 2009
Somewhat Helpful
I found this excellent narrative at Tiger Direct of Canada. This is open information I just wanted to give credit for the method used by Tiger Direct to present this sometimes difficult to understand subject
  1. The way size is calculated and displayed.
  2. Any "Partitions" on the disk will change the total in a specific partition.
  3. Hidden files and folders decrease available space.
  4. Compression increases the apparent size, but not the physical size.
  5. Drives larger than the OS or Drivers natively supports.
First, the definition of a megabytes (or gigabytes) is a unit of data storage capacity measured in 1,048,576 bytes (or 1024KB). The larger the numbers, the more apparent the size difference will be when listing the size as megabytes (or gigabytes) versus bytes. Actually, both numbers are correct. The noticeable difference is due to the 1024KB definition of a megabyte. This is why a 95.3GB hard drive can also be listed as having 102 billion bytes of total space. Just think of it as "round off" In the screen shot at right: The first number is the total number of bytes, the second number is based on the number of megabytes or gigabytes.
Second, some computers have a non-DOS hard drive partition that is used for features such as Save to Disk, Hibernation, or Recovery. This partition is not normally reported by the operating system, although it can be viewed using a disk partition utility. This is very common on desktops and laptops. NOTE: Partition information will be created or formatted automatically during initial system setup and a system recovery.
Third, by default, all system files are hidden and cannot be seen. This may adversely affect the reporting of available hard drive space. You can set your Folder Options so you view system and hidden files and folders, but do be careful as changes to system files can adversely affect your system.
Fourth, if you turn on Compression for a drive, it will increase reported free space and used space, but since compression is based upon the actual contents, this number is not fixed, but will change as files are added or changed.
Fifth, older operating systems did not support some of today's larger drives, so the total space reported may be much smaller than the drive specifications.
It is also worth noting that bad sectors are corrected by your operating system and can change the total drive space, free space, or used space as well.
So as long as a drive is reporting a value approximately close to the specification value, you can be comfortable that you received the right drive and that you are getting to correct data storage. Of course, tuning of your drive's partitions and options can yield optimal values, but this is not something for the average user to explore.
Additional information on this topic can be found here:
http://en.wikipedia.org/wiki/Hard_disk_drive
http://simple.wikipedia.org/wiki/Hard_disk
Was this helpful?
Yes
No
Can you Help with these Hard Drives problems?
Hard Drives
Emachine acer E627 my laptop wont start up as normal and...
Hard Drives
How do you do a firmware upgrade on a Cyclone HDMI 1080i?...
Hard Drives
I would like a user manual for a Samsung Story external...
Hard Drives
I've got a big problem in my External Hard ( Maxtor...
Seagate 1 TB SATA II Hard Drive
Subject: SYBA SD-SATA-IDE-B Tuesday ? 25 August 2009 When...
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
