Tip & How-To about Sony Playstation 3 (PS3) Console
PS3 and XBox Disconnecting network problems.
This tip helps those who connect through a router to use the PS3 or XBox online.
Whether you connect wired or wirelessly, you should get into your routers setup page from a computer, and make the DHCP always assign the same IP address to your PS3 or XBox. Then place that IP address into the DMZ of your router. Save your settings and voila! No more NAT conflicts.
Sony Playstation 3 (PS3) Console Logo
i have a belkin connect n150. and i hav my ipod touch connected to it via wireless and my computer and xbox 360 via wired and i can connect to the internet on my ipod and computer and xbox. but when i try playing online it wont start a match it keeps saying finding players.
PS3 And XBOX :: BELKIN
Step 1:Connect Modem - Router - Computer (Wired)
Step 2:Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3:On the Left click firewall
Step 4:Leave the Password blank and click submit
Step 5:Disable it and click apply changes
Step 6:Scan and connect in the Xbox/PS3/Wii
Step 7: Get the IP Address of the Xbox/PS3/Wii
Step 8:Open Router Setup in the Computer
Step 9:On the left under Firewall Click DMZ
Step 10:Enable the IP Address of the Xbox/PS3/Wii in it
Step 11:Click Apply Changes
Step 13:On the left Under Utilities click System settings
Step 14:Scroll down to the bottom
Step 15:Enable UPnP
Step 16:Click apply changes
Step 17:Test the connection ,Check the NAT
If working then let me know
If it is still not working
Open Router setup
At the middle Under internet settings check the WAN IP
IF it starts with 192.168. or 172.16 Then you will have to contact your internet service and ask them to bridge the modem
Regards
TOM
Jan 15, 2011 | Belkin Connect N150 Wireless N Router
my xbox 360 says im connected to xbox live checked network setings and it says xb ox live is up and running...however when i try to play need for speed online..it says xbox live not working functionally? wtf
Turn on the console and navigate to the wireless settings screen. On the Xbox, the menu path is "Settings -> Network Settings -> Advanced -> Wireless -> Settings" On the Xbox 360, the menu path is "System -> Network Settings -> Edit Settings." Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there. Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.) Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead. Note that the standard Microsoft Xbox 360 Wireless Network Adapter supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740) only supports WEP. Save your settings and verify the network is functional. On the Xbox, the Wireless Status screen displays whether a connection has successfully been made with the wireless router, and the Connect Status screen displays whether a connection has successfully been made through the Internet to Xbox Live. On the Xbox 360, use the "Test Xbox Live Connection" option instead.
If you need more help post back! Thumbs and testimonial are welcome!
Jan 15, 2011 | Computers & Internet
Ps3 and Belkin surf router - I can play online with the ps3 but when i try to join with friends to form a party (Black ops) it will not allow me to do so. any suggestions? i did not have this problem before I installed the wireless router.
Step 15:Enable UPnP
Open Router setup
Dec 13, 2010 | Belkin Wireless Surf Router (F7D2301)
ps3 online
ps3 has a built in wireless adapter.rather than having wires all over, get a wireless router.connect the router to your modem with an ethernet.once you have the wireless router up and running,you will have whats called an "access point" for any devices to connect to wirelessly (within a reasonable distance),such as the ps3.
Dec 30, 2007 | Sony Playstation 3 (PS3) Console
480 people viewed this tip
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
