Tip & How-To about Yamaha HTR-5650 Receiver
Reset factory default settings for yamaha HTR-5650 AV receiver
How to reset yamaha HTR-5650 AV receiver (maybe others) to factory default settings:
1. turn power off.
2. press the 6ch input and stereo button simultaneously for 4 seconds. Then while holding down these 2 buttons, turn the power on.
3. press preset tuning to the right until option #9 is selected.
4. Then, press program button until the *RV option is selected.
5. turn power off, wait 10 seconds.
6. turn power on, settings are reset.
Yamaha HTR-5650 Receiver Logo
What's your problem?how to reset yamaha htr 3065 to factory settings
I had the same trouble to reset this machine into factory setting and finally, I found out. Let's do this way.
- Leave your remote away as you won't need it
- Turn off the the unit to STANDBY mode
- Press and hold STRAIGHT button on the unit and press Power button while you are holding it. This will turn on the machine.
- Once the machine turns on, press PROGRAM to select the items on LCD display until it shows INIT **** CANCEL
- Press STRAIGHT button until it turns to INIT **** ALL
- Press Power to turn off the machine.
- Leave it for 2 sec. then turn on the machine again.
Now your unit turns to factory default setting.
Feb 25, 2013 | Yamaha HTR-3065
how to reset a yamaha 5440 reciever back to factory settings
Hold 'fm/am' and 'input mode' and press power button. Then cycle through menus using 'program' button until you come to the selection that says "preset inhibit". Then press 'preset/tuning' button to change it to "preset reservd". Then press power button to turn it off. When you turn it back on, it should be back to factory settings.
Dec 30, 2012 | Yamaha HTR-5440 Receiver
How do I reset my yamaha receiver htr5730
http://www.retrevo.com/support/Yamaha-HTR-5730-Receivers-manual/id/1075bh230/t/2/
Page 52
1 Hold down STEREO on the Front Panel
"Factory Preset" appears on the front panel
2 Press STEREO to select the desired setting.
'Reset' To reset to factory presets
'Cancel' to cancel without making changes
3 Press STANDBY/ON to confirm your selection
Jan 15, 2011 | Yamaha HTR-5730 Receiver
Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Is Yamaha HTR-640 a receiver? Try HDMI from PS3 to receiver or Sony HDTV. If HDMI from PS3 to receiver the you need and HDMI from receiver to out Sony HDTV. You could connect everything to receiver and HDMI out to HDTV. You can not have an HDMI cable AND an optical cable coming out of the PS3, only one or the other.
Dec 30, 2007 | Yamaha HTR-6130 Receiver
4,849 people viewed this tip
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
