Tip & How-To about WYSE WT3235LE (902032-68) Network Terminal
Reset a WYse WT3235LE back to Factory setting.
Hold down the G key when powering on and during the booting process to reset it back to factory settings. You can also do this in Control Panel under System.
NOTE: The G key trick is very picky so make sure you hold the G key before you press the power button and until it is booted. Also don't be frustrated if it doesn't work the first time.
WYSE WT3235LE (902032-68) Network Terminal Logo
My icraig tablet locks up during the boot loading screen process
I've never heard of this tablet before since there are so many android tablets out there, from reading a bit seems to be an issue with them locking up on people during boot. Charge the tablet, hold the power down+volume down key till you see the android recovery menu, you can either select clear app cache that might fix your issue. If that doesn't you need to select perform factory reset, this will wipe all the data and return hopefully the tablet back to its factory settings.
Feb 20, 2015 | Computers & Internet
clear cmos
if you want to reset your password or your cmos
When you boot up to the log in screen type in administrator as user to log in if you cant log in
Restart your computer during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there
if this fails to remove your password
The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased.
click start control panel Open User Accounts in Control Panel. On the Users tab, click the name of the user whose password you want to change, and then click Reset Password. In New password and Confirm new password, type the new password, and then click OK. Notes You can change passwords only for local computer accounts, such as guest, administrator, or accounts you create for your computer. You cannot change your network logon password in User Accounts. To change your own password, press CTRL ALT DELETE and then click Change Password
also
if you are not the computer administrator and have not assigned a bios password during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up Press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there also click start control panel user accounts on the users tab,click the name of the computer administrator you must have full control can change the password there
hope this helps you
start a windows xp system up n safe mode then click on control panel ten user accounts then the specified user which is password protected and it allows you to change the password without knowing the original one. Restart the computer. Repeatedly press the F8 key until the Advanced Boot Options screen appears. Select the Safe Mode option using the up and down arrow keys, then press the ENTER key. Choose "Windows XP Home/Professional", depending on the version of the operating system. Press ENTER. Shortly, the welcome screen should show.
Log in as "Administrator". Click Yes to not use System Restore Mode.
Click the Start button. Choose Run and type in "control userpasswords" (without the quotes). Click OK.
Select the "Administrator" user. Click Change my password. Enter a new password in the corresponding text boxes. Click OK. Write this password down and store it in a secure place. I do not recommend that a password hint be used.
Close the User Accounts window and restart Windows.
hope this helps you
Sep 29, 2011 | Intel D946GZTS Motherboard
I need to reset my password on my Dell Studio 1535.I forgot what it was and cannot start up without
also
hope this helps you
Click the Start button. Choose Run and type in "control userpasswords" (without the quotes). Click OK.:
Close the User Accounts window and restart Windows.:
hope this helps you:
Sep 26, 2011 | Intel D865GLCLK Motherboard
I need to reset my password on my desktop. I forgot mine
also
what computer and which operating system?
hope this helps you
Aug 25, 2011 | Computers & Internet
dont have adnimastraighter password and want to reboot my laptop from manufacture sales
i hope you mean manufacturer (factory default settings)if so
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer)
as for the password
When you boot up to the log in screen type in administrator to log in if you cant log in
also
on the users tab,click the name of the computer administrator you can change the password there
Hope this helps
Jan 02, 2011 | Computers & Internet
2,097 people viewed this tip
Top WYSE Computers & Internet Experts
Nicholas Bannister
Sunday Ojelabi
Sunday Ojelabi
Are you a WYSE Computer and Internet Expert? Answer questions, earn points and help others
