Tip & How-To about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Washer Repair Manual & Parts Links
Hello ... I found these links at http://www.applianceguru.com/forum2/7735.html while searching for the solution to my problem and figure they will help for a lot of you!
This link is for the Duet Washer Repair Manual in .pdf format https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/eab852a13fbc842085256aa200643dd6?OpenDocument
Lots of good info ... including how to check the relays.
They also included this link as a source for parts (this one is for the door latch assembly) http://www.repairclinic.com/SSPartDetail.aspx?PartID=1094190&PPStack=1
Many thanks to the guru! Just passing on his information.
Whirlpool Duet GHW9150P Front Load Washer Logo
What does a blinking LE mean?
The internet is rife with people with LE errors on LG Washers please look at links below, but this is what it "officiially" means: dont forget to vote ta
LE LOCKED MOTOR ERROR
• The connector (3-pin, male, white) in the MOTOR HARNESS is not connected to the connector (3-pin, female, white) of STATOR ASSEMBLY.
• The electric contact between the connectors (3-pin, male, white) in the MOTOR HARNESS and 4-pin, female, white connector in the MAIN PWB ASSEMBLY is bad or unstable.
• The MOTOR HARNESS between the STATOR ASSEMBLY and MAIN PWB ASSEMBLY is cut (open circuited).
• The hall sensor is out of order/defective.
http://www.howtomendit.com/answers.php?id=28214
http://applianceguru.com/forum2/7726.html
Thanks to
http://applianceguru.com/forum2/7726.html#ixzz1CwXM5vaa
Feb 03, 2011 | LG Washing Machines
Keeps giving me the F1 signal. Whats the deal?
Fellow, Academy of Sublime Masters of Appliantology
Joined: Sun Oct 7th, 2007 Location: South Carolina USA Posts: 6784 Flavorite Brew: waffle house coffee Status: Offlinespacer.gif F1 usually means a communication or an electrical error.
Unpgug the machine for 1 minute and then power back up. If fault reoccurrs check all connectors.
How long have you had this machine? Has it always been plugged into the same outlet? Is is sharing an outlets with another device?
Read more: Whirlpool Cabrio F1 code - The Laundry Appliance Repair Forum - Do-It-Yourself Appliance Repair Help - ApplianceGuru.com: The Samurai Appliance Repair Forums http://applianceguru.com/forum2/15527.html#ixzz1BPYo9agm
Get appliance parts at http://parts.fixitnow.com
Jan 18, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
the ice maker doesnt make ice and the vacuum condenser warning always is on. even when I turn off and on and vacuum
Your unit may still be under warranty- the following blog has the warranty lengths (in years):
http://applianceguru.com/forum1/16671.html
Here is a general ice-making troubleshooting guide that may help you:
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
Here's what a tech on applianceguru.com says about the vacuum condenser problem:
The vaccuum condensor light just means one or more compressor in the unit has excessive run time, you need to have this unit checked, your compressor(s) are running too long for some reason so might be a sealed systen problem developing.
Read more: Subzero says vacuum condenser - The Kitchen Appliance Repair Forum - Do-It-Yourself Appliance Repair Help - ApplianceGuru.com: The Samurai Appliance Repair Forums http://applianceguru.com/forum1/2410.html#ixzz14kiAdO9r
Get appliance parts at http://parts.fixitnow.com Since you have a sealed system, a tech will have to come check it out and troubleshoot it. Hope it's still in warranty, and good luck.
Nov 09, 2010 | Sub-Zero 690 Side by Side Refrigerator
water not entirerly draining, e04 code continues on...
http://applianceguru.com/forum2/14805.html
Wow - I can't believe it. I had the SAME problem and searched the internet. This was the first site I found and was initially discouraged since there was NO solution, but upon further searching, I found the answer. I'll post the site here http://applianceguru.com/forum2/14805.html and you can just hop on and find out the answer in a much more helpfully worded way than I could ever do it!
I found a girls bobby pin and a rubber band stopping my drain from functioning! I thought it would FOR SURE be legos, but those boys are off the hook!
May 31, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
2,406 people viewed this tip
Dan Webster
Dan Webster
Sal DeAngelo
