Tip & How-To about HP Compaq ProLiant ML350 G3 Server
Windows Server 2008 Network Driver for Proliant ML350 G3
Anyone who has tried loading Windows Server 2008 on their Proliant ML350 G3 has found that HP does not offer the network driver for this system.
BUT, the Windows Server 2003 driver for the NC series Broadcom 1gb will work! Rather than choosing the 'install' option, choose to 'extract' it, then via the device manager, manually install the driver from that location.
Happy Computing!
HP Compaq ProLiant ML350 G3 Server Logo
I need Network card (LAN) driver for HP Proliant ML350 5G server.
Go the website of HP, chose for the support and drivers - lookout for drivers and software - enter your product name i.e HP Proliant ML350 5G Server and click on search.
You will get the list, select your product. Select the operating system you are using on your server - then choose the driver type - click suitable, from the list of drivers and download it.
Apr 23, 2013 | HP ProLiant ML350 G5 Server
driver for lsi1030 ml350
install latest hp proliant servicpack
May 09, 2012 | HP Compaq ProLiant ML350 G3 Server
i have installed windows 2008 server on HP ML 350 G3 and has refused to see the network
Hello, This could be many thing that causes this. 1. I would check the network properties to make sure the network ports are configured correclty. 2. Make sure the network services are turned on. 3. Make sure you have install the latest service pack for server 08 and your network drivers. Once done, reboot.
Good Luck
C2Solutions
Sep 26, 2011 | HP Compaq ProLiant ML350 G3 Server
install an operating system (Windows Server 2008) on a used HP
Hi, Have you checked the BIOS? Check the Backup ROM option (change to Backup ROM)
If you haven't change the Boot Order: Go into RSBU and change the Order.
Note: If you have Scsi you do not need to do any additional things rather than this. If your product has a Smart Array Controller, during the POST, press F8 during the Smart Array controller ID to access the configuration utility, delete and re-create the disk array to wipe out whatever might be on the disks.
Feel free to contact again. Let me know what happened.
Thanks for contacting Fixya! (Please rate the answer as well)
Jun 25, 2010 | HP Compaq ProLiant ML350 G3 Server
iTS NOT LOADING WINDOWS
If it is not booting at all then the disks will not be configured. Better boot the server using the HP utility CD and install the OS after creating the right array and partitions.
Jan 04, 2010 | HP Compaq ProLiant ML350 G3 Server
4,503 people viewed this tip
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
