Tip & How-To about Microsoft Windows XP Professional
Driver Troubleshooter Permanent
Once you have already installed a driver for a new device and after some time when you search the cd and you dont find ..and at that condition you have to format the computer what will you do??
Just follow the steps.
1.copy c:\windows\system32\drivers toa backup cd
2.also copy c:\windows\inf to backup cd
3.thats all you will now have the backup drivers for all devices that you had
now if you try to locate the drivers in the cd windows will automatically find all the drivers there.
Microsoft Windows XP Professional Logo
roticul manual mfg990695
Manually installing a driver software is easy,
Right click my computer icon, select properties, then select Hardware Tab, Select Device Manager. Then select hardware we want to install , Right click and select update driver
-A screen will pop up like in the automatic install. Select "install for a list or specific location" this time and click next. Uncheck "search removable media" and check "include this location in search". Click the browse button and go to the directory where you saved your new driver. (if its on CD just search removable media and it will find it).
-Click next and it will attempt to install the driver. Once done click next and your new driver is install. A reboot might be required for the device to work properly.
http://consumersupport.lenovo.com/in/en/DriversDownLoads/APR_Driver_List.aspx?CategoryID=12&OS=Windows%20XP
May 05, 2011 | Computers & Internet
i dont have sound on my computer @ the moment, would somebody help me? my mother board is p4 titan ga 8pe800.. plz... tnx much!
Go to this link http://kickasstorrents.com/
Search universal xp drivers CD
Download CD using torrent download CD
To install drivers go to my computer properties
Click on device manager
Install drivers using update device driver...
Browse the downloaded drivers in the given window..
After installation restart your system once...
Dec 05, 2010 | Intel Computers & Internet
my computer says found new hardware but when it tryies to install it says there was a problem does a search and finds nothing. So i cant update the firm ware,i already formated the zen but it did nothing different
When you experience next making connection:
Connecting the device to the computer Wizard found new hardware pops up.
Only this time the Windows update searching for software will not work on automatic routine:
ending up with "Cannot Install this Hardware".
Solution:
Manual performing the wizard, setting the device to USB connection type:
1. Can Windows connect to Windows Update to search for software ?
Select "No, not this time".
[Next]
2. If your hardware came with an installation CD, or floppy disk, insert it now.
Select "Install from a list or specific location(Advanced)."
[Next]
3. Please use your search and installations options.
Select "Don't search I will choose the driver to install."
[Next]
4. Select the device driver you want to install for this hardware.
Select "USB Mass Storage Device."
[Finish]
Note: when using MSC mode always safely remove hardware, the players' removable disk. The icon in the right corner of the task bar.
Once the device can be reached in MSC mode it should be ready to install new firmware on the player:
1. Backup data on the player to the computer when not on the PC already.
2. Reinstall / update firmware from computer to the player: after this the device will have all the maps for writing data and it can be approached in MTP mode again, using application software like Windows Media Player 11.
Need more help, just post a comment.
Oct 07, 2009 | Creative Labs Creative Technology Zen MP3...
sound driver
Hi sgs182, when a driver fails to install correctly its best to install through windows device manager. Suggest you try this method of instillation before trying another HD audio driver. Also enter your bios & make sure the HD is enabled.
Either use the driver CD that came with the motherboard or download the driver from Biostar. Windows 2003 is more like window XP however we both know what you need is a driver for 2003. Biostar makes other P4M890-M7 motherboards that do support win 2003 for HD.
· P4M890-M7 TE 7.x
· P4M890-M7 SE 7.x
· P4M890-M7 PCI-E 7.1
· P4M890-M7 PCI-E 7.0
· P4M890-M7 FE 7.x
Biostar motherboards 7.0 & 7.1 audio drivers are the same file size of 24.77MB & support x86/2003 operating systems.
How to install through windows device manager?
Left click once on the start button. Slide up to & left click on control panel. Find the System icon & open it. Left click on the hardware tab than left click on the device manager button. Scroll down to Sound, video and game controller, which should already be opened. You should see a yellow explanation point here.
Right click once on the yellow ! point & left click once on update driver. Windows hardware wizard will open. Click No, not at this time. Than click the next button. Another window will open. Left click once in the circle next to, Install from a list or specific location (Advanced). Than click the next button. Again, another window will open. We want to remove the green check mark next to, Search removable media (floppy, CD-ROM...). (Only if you do not want to install from the CD).
Click the green check mark once & it will go away.
Click the browse button, click the + sign next to my computer. Find the desktop folder
You created & named. Open it. High-light the folder that has the driver in it & click ok.
Windows will find the correct driver software within the folder & install it automatically. Once completed. Close all opened windows & restart you’re system. Test your audio. If you intend to use a mic, you will need to set this up through the Sounds audio device within the control panel.
Mike
Sep 22, 2008 | Biostar P4M890-M7 Motherboard
my cd/dvd opens then closes
> I've already replaced it once
Well, I've seen CD-drives that would re-open, when you try to close them -- it is _falsely_ detecting a "jam" as the tray is closing, and then just re-opens the tray, rather than "forcing" itself to close.
Replacing the CD-drive is the only way to fix that type of "false-positive" jam-detection conditions.
But, since you've done that, either you were unlucky-enough that the replacement drive was also "defective", or, you have a computer-virus on your computer that is maliciously issuing commands to the CD to "open-the-tray".
Sep 20, 2007 | Compaq (224130-001) Internal 4x CD-ROM...
332 people viewed this tip
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
