By
ginko
Rank: Guru
Rating: 89%, 4891 votes
posted on Jan 31, 2009
IE is inlet error, displayed when "Not reached to the normal water level in spite of 10 min. water supply"
Possible cause:
- The Water Supply Tap is closed.
- The Water Supply is shut off.
- The Inlet Hose is kinked.
- The Water Pressure is very low.(below 10 psi)
- Inlet Valve is OK?
- The filter of Inlet Valve is clogged by impure water.
- The Hall sensor is OK?
- The Impeller of Air Guide is bound.
Remedy:
- Cut power by tripping circuit breaker or unplugging power cable for ten minutes.
- Take action on Water Supply device.
- Measure the electric resistance of Inlet Valve. (950-1300 )
- Clean the filter of Inlet Valve.
- Check the frequency of Inlet Water by the Test Mode.
- Replace the Air Braker.
Was this helpful?2 people thought this was helpful
Comment #1
posted on May 23, 2009
By
DelGradPhi
Rank: Apprentice
Rating: 0%, 0 votes
LG should pay you to write the manual... I've been plagued by the IE error coming on intermittently for months - cleaned every filter mentioned in the manual... but it doesn't even mention that an inlet filter exists! So one minute reading this site and three minutes cleaning the inlet filter saved me a $200 service visit. Thank you!!
Can you Help with these Dishwashers problems?
LG 24 in. LDS 5811 Built-in Dishwasher
Our Dishwasher is not drying the dishes....Heating...
I have an lg front loading dishwasher model LDS5811bb. It...
my dishwasher starts for a short time then an alarm goes...
dishwasher starts for 5 mins and then a alarm comes on and...
it leaks from under the front door, escpecially when it...
