Tip & How-To about Nokia E61 Smartphone
Current Software version
To find current software version just enter *#0000# on your phone's keypad.
Nokia E61 Smartphone Logo
I REQUIRE LATEST SOFTWARE UPGRADE NOKIA 5800
The latest software version of Nokia 5800 is version 60.0.003.You can do it via OTA (over the air) thru GPRS (mobile service providder's internet gateway) or via wi-fi connection or even via PC suite.
OTA via GPRS:
1. type *#0000#2. the current software version will be flashed on your phone's screen3. select option4. select check for updates5. it will ask you to connect via your mobile service provider's connection.5. select yes6. it will give you the current available updates for your phone7. if it's available for your phone, it will be displayed for the latest version for the version 60.0.003's availability varies per region.8. once available, select update then it will be automatically downloaded to your phone then once done phone restarting, you will have the version 60.0.003, you good to go...
VIA Wifi:
1. type *#0000#2. the current software version will be flashed on your phone's screen3. select option4. select check for updates5. it will ask you to connect via your wi-fi home network connection5. select yes6. it will give you the current available updates for your phone7. if it's available for your phone, it will be displayed for the latest version for the version 60.0.003's availability varies per region.8. once available, select update then it will be automatically downloaded to your phone then once done phone restarting, you will have the version 60.0.003, you good to go...
VIA PC SUITE:
Go to this address and follow instructions (make sure that you have available USB cable for your phone for you will need to connect to your pc to do this):
www.ovi.com/softwareupdate
thanks for choosing fixya.com
Dec 17, 2011 | Nokia 5800 XpressMusic Smartphone
I want to update nokia e5
You need active internet connection for this:
1. press #0000#, then it will display you the current software version that your phone is using.2. press option, then select check for updates.3. it will then go to connecting to internet, select yes.4. if there is available update, you will be provided instructions that the phone is updating software.5. you will be ask to replace the old version with the new version, just select YES.6. your phone will restart, that's part of the software update.7. after restarting, your phone will now be using the latest version available for your phone.8. you can again check the current version of the phone's software by entering *#0000#, then you are good to go.
You can also try to this:go to settings --> software update --> download available updates --> phone will restart --> you will be using the new version of the phone's software after this.
Thank you for choosing www.fixya.com
Dec 08, 2011 | Nokia E5 Cell Phone
please help.,.,i need my license key.,., imie 35227201819836.,., thanks
insert code :
*#92702689# - takes you to a secret menu where you may find some of the information below:
1. Displays Serial Number.
2. Displays the Month and Year of Manufacture
3. Displays (if there) the date where the phone was purchased (MMYY)
4. Displays the date of the last repair - if found (0000)
5. Shows life timer of phone (time passes since last start)
and
View the firmware version of the phone
Dial using the keypad: * # 0000 # - the version number displayed on the display.
like this example :
V 5.16
22-06-99
NSM-1
V 5.16 - software version
22-06-99 - date
NSM-1 - The hardware (model)
View IMEI
Dial using the keypad: * # 06 # - IMEI number is displayed on the display.
i hope this helpful
thank you for using fixya
Feb 07, 2011 | Nokia 6600
My panasonic kx-tsc10mxw keypad locked
take this:
1- Press Function
2- Press Down button until menu “Change password” displayed -> ENTER
3- " Current password " : Press this Number "726276642" -> Enter
4- “New password”
5- 0000 ENTER
6- EXIT
7- Press DIAL LOCK KEY
Jul 12, 2009 | Panasonic Lands Phones
locked keypad
Try the last four digits of your phone's number, then 0000, 1234, etc...
Did you reset the PIN yourself, or is it the default PIN? If you didn't change it yourself the above mentioned will probably unlock it, if not, you may have to take it into a service providers Corporate location and have a Tech. unlock it.
Good luck.
Apr 05, 2008 | LG KG800 Cellular Phone
1,449 people viewed this tip
Top Nokia Computers & Internet Experts
Computer Links
Gopi Venkatesan
Gopi Venkatesan
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
