Tip & How-To about Brother GX-6750 Typewriter
Reset Trick
Insert the printwheel and close the cover, it will automatically go to the proper position, unless there is something wrong with it.
Brother GX-6750 Typewriter Logo
how i can shift to arabic
You have to buy an Arabic printwheel and install it.
To insert the daisywheel:
1. Open the top cover.
2. Pull the lever toward you to release the daisy wheel lock.
3. Remove the cassette daisy wheel by pulling it out of the machine by the protruding "ear" on the top right.
4. Insert the desired cassette daisy wheel into the slot and press down gently.
5. Slide the lever back to its original position to lock the cassette daisy wheel into place. Make sure to press the lever firmly.
6. Close the top cover.
7. Press and hold the CODE key. While holding CODE press the Q key, this will move the carrier to the previous position.
Sep 11, 2013 | Brother SX-4000 Typewriter
how do I change the ink cartridge?
Follow these steps:
  • Make sure the power light is on.
  • Raise the front cover.
  • The cartridge carrier moves to the middle for the loading position, unless the printer is busy.
  • Pull the cartridges toward you until you hear a snap.
  • Remove the used cartridges. Store them in an airtight container or dispose of them properly.
  • Load the new cartridges and snap them into place.
  • Close the cover.
NOTE: Sometimes the ink cartridge carrier won't position automatically to the middle even when the printer is on and the cover is open. Just unplug the printer from the power source. With the cover open, hold the solid white strip and gently slide the carrier to the middle of the printer. Load the cartridges. Close the cover. Plug the printer back to power source.
Sep 14, 2010 | Lexmark Z715 InkJet Printer
reset code for daisy wheel
check this link on which printwheels work with your model to make sure you have the right one. There is no reset, except after you insert the printwheel and close the cover, it will automatically go to the proper position, unless there is something wrong with it.
See the instructions on page 12 of this manual:
http://www.brother.ca/en/products/pdf/manuals/GX6750-UG.pdf
Jan 18, 2009 | Brother GX-6750 Typewriter
How to load the ink cartridge
keep the printer ON.then just open or lift the front cover .the cartridge carriage will move for a minute automatically and then stop at a position where u can remove the cartridges from the printer and install the new cartyridges.just pull the old /used cartridges from the printer towards you.and in the same way insert the new cartridges in their respective sockets properly.close the cover.and your cartridges r installed.
Nov 19, 2008 | HP Office Equipment & Supplies
Print Cartridge wont fit back on properly
Take the print cartridge out. Close the lid and turn the unit on...the carrier will go the the left and buzz (finding home position) . lift he lid, look at the back of you print cartridge and you will find a little silver ball. rotate this until it is at the top (12 oclock) put it back in the machine and close the mechanism...firm but not too hard, it should click...close the lid and it should home out again..you should see the printwheel move...that should do it.
Jan 03, 2008 | Brother GX-6750 Typewriter
1,269 people viewed this tip
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
