Tip & How-To about LG CHOCOLATE VX8500 Cellular Phone
Battery Water Damage
When you get a brand new phone, beware do not allow any moisture or water around your phone. I say this because the new phones have water detecting stickers near the battery and when this display that there was water damage the phone carrier may not help you with problems regarding your battery. Picture courtesy of: http://www.danlockton.co.uk/research/images/phonesticker2.jpg
LG CHOCOLATE VX8500 Cellular Phone Logo
i call have water damaged what should i do ?
Follow these procedure to save or revive your phone, remove Cell Phone from Water: Time is of the essence when it comes to saving a fixing a submerged cell phone, as soon as you see your phone in water, remove it quickly! Every second matters do this step quick.
Saving the Battery: In order to save the battery on your cell phone after it's been wet, quickly take the battery out of the phone as soon as you take it out of the water. Buy doing this you will ensure that minimal damage is done to your battery.
Drying the Phone Out: Quickly shake your cell phone to get all of the water out and reach for the paper towels. Press down on your cell phone to make sure all of the excess water has come out. If you have accessories such as cell phone covers, take them off promptly otherwise water will still be stuck in your phone.
Saving your Info: If your cell phone takes a SIM card, quickly remove it before the phone dries. While you may still loose some of your information, you won't lose it all if you take the SIM card out of your cell phone in time
.Removing Excess Moisture: To remove the unseen moisture in your cell phone you will need to cover it with either Desiccant gel packs or rice. Desiccant gel packs can sometimes be found when purchasing brand new shoes or clothes. Make sure your cell phone is completely covered with either one of these for up to 3 hours.
Vacuuming: Take your vacuum hose and place it up to 4 inches away from your cell phone with it on. While this won't remove all of the water, it will certainly eliminate the big spots of water damage.
Turing the Phone On: After allowing your cell phone to sit a day or two with the power off, turn it on to see if it works. More than likely if you followed these steps as soon as your phone was submerged, it will cut on. If not, you will have to purchase a new cell phone because the one you have can't be saved.
Take care.
Jul 21, 2010 | RIM BlackBerry Storm 9530 Smartphone
HOW TO REPAIR WATER DAMAGE GT-S5620 BRAND NEW
First of all, do not turn it on, it could cause more damage to your phone. Take out the battery, and completely dry the phone before trying to use again.
Here is the procedure to take out all moisture trapped in the phone: Dry the phone, battery, any accessory, etc. with cloth and wrap each piece, phone and accessories, in newspaper. Place a few handfuls of rice into a plastic bag and then place the wrapped phone in the bag with rice. The newspaper wrapping avoids direct contact of rice with your phone because the dust from the rice can get into the small areas of the phone. The newspaper and rice will absorb moisture. Leave it there (with the bag open) at least 24 hrs. Hope this helps!
Jun 08, 2010 | Samsung SGH-a737 Cellular Phone
My Phone went through the washing machine, but the cmaera worked for a while, then after about 2 weeks it stopepd working it says "unable to open camera" ive tried resetting it, but i dont know what else to do.
new phones has built in humidity detection that save the phone and not for water I know one that did same and used hairdryer and worked good you may need to replace your phone sorry for the bad news
Sep 09, 2009 | Motorola Mobility RAZR V3
some buttons on the keypad won't work
I strongly recommend consulting the supplier, he/she is bound to know what to do, they may also give you a new handset!!, by the way may i comment on the good phone!!, but yeah, if they are unable to help, take it to a certified phone shop/dealer, they will know what to do!! BUT DO NOT mess around with it yourself!!, this could void your warranty and may definitely do more harm than good! is there any water damage, i have researched and found that this problem happens A LOT when there is water damage on the phone, check the moisture on the battery, there should be a moisture detector on the top of the phone, if this is pink, than it has been affected by water damage, ive also found someone who used SEUS to flash his phone, he said that the buttons were stuck and he had the same problem as you, when he flashed it he said that the phone had restored itself! i recommend trying it yourself BUT BEWARE that you can void your warranty if you do so!! but definitely contact the owner first!
hope this helps and keep ion touch!
Jan 09, 2008 | Sony Ericsson W850i Cellular Phone
Water Damage
this is a stick and whens it get wet it change color into red.dont be worry is nothing
Aug 20, 2007 | Motorola Mobility RAZR V3m Cellular Phone
3,192 people viewed this tip
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
