Tip & How-To about AT&T BlackBerry Curve 8310 Cell Phone - Red
How to Reset your Blackberry (Wipe Handheld)
If you want to reset your Blackberry phone just follow the simple steps below and you phone will be reset to factory settings in less than 5 minutes.
Step 1.
From the Home Screen choose Options
Step 2.
Now choose Security Options
Step 3.
Select General Settings
Step 4.
Press the Blackberry Button (the button to the left of the trackball)
Step 5.
Scroll down to Wipe Handheld
Step 6.
A new screen will pop up asking if you are sure. Choose Yes to continue and then you will be prompted to type the word "blackberry" for confirmation.
Step 7.
Wait for your device to reboot and viola your Blackberry has been reset.
AT&T BlackBerry Curve 8310 Cell Phone - Red Logo
how to reset password in blackberry 9720
Are your referring to reset username and password for blackberry account. If yes, please refer steps below to reset the password
1. Visit http://global.blackberry.com/en/bbid.html and complete the instructions on the screen.
2. You are prompted to sign in with your BlackBerry ID, click Forgot Password. Answer your security question and complete the instructions on the screen.
Once you have completed the steps above, you will receive a password reset email. If you complete the steps to reset your password on a computer, the password reset email can only be viewed on a computer and isn't delivered to your device. If you follow the steps to reset your password on your device, the password reset email will be delivered to your device. Complete the instructions in the email to reset your BlackBerry ID password.
Note: You cannot reset the User ID, if in case you need to change your user id you need to create new BBM account.
GuruAid.com
Oct 30, 2014 | Blackberry 9720 3G, 5MP, OS 7.1, Qwerty...
how to factory reset
Follow below steps:
From the home screen, scroll to the All tray and press the trackpad.
Scroll to Options and press the trackpad.
Scroll to Security and press the trackpad.
Scroll to Security Wipe and press the trackpad.
Scroll to the desired options and press the trackpad to check or uncheck as desired.
Enter blackberry in the text field.
Scroll to Wipe Data and press the trackpad.
The handset will completely reset and restart.
This will take several minutes.
Jan 04, 2014 | Blackberry Curve 9310 Black Smartphone -...
i want unlocak my blackberry mobile 9300 curve plz tell me how can i do
Get the code from service provider and Unlock it...
Aug 27, 2011 | AT&T Cell Phones
hvb error on blackberry bold 2 ...not able to re boot
Hi, you can try and reset the phone with the following instructions below. worked for me.
How to Reset a Blackberry
There are three main types of Reset that apply to the Blackberry. These are listed in order below. Instructions for Blackberry Pearl are slightly different - see bottom section of the Tip.
1) Soft Reset - simply press the ALT+RIGHT SHIFT(CAP)+DELETE keys.
This reset stops all applications that are running on the Blackberry and will help if you are having problems connecting the device to computer. This reset will not erase any information from your device.
2) Double Soft Reset - this reset is almost equivalent to a full hard reset. First perform a Soft Reset as outlined in Step 1.
As soon as the screen is no longer black - repeat the steps once again exactly as before.
This takes you to another screen showing an hour glass. Allow the device to reset. This helps if the device has suffered a more serious error. Be aware you may loose some information from your device. A backup is advised prior to proceeding if at all possible.
3) Hard Reset - this is the full blown reset and will fully reset the device to help resolve critical errors with software or hardware. Again back up important information before proceeding if possible.
Note: For RIM models 850, 857, 950, or 957, you must insert the end of a paperclip or similar blunt object into a small recessed hole on the back of the unit and depress the switch inside. The device will reboot and be hard reset.
Other Models: With the device turned on - remove the battery for 30 seconds or more. Now replace the battery. The device will reboot and be hard reset.
Blackberry Pearl: To reset to factory defaults enter 'Options' from the main menu. Scroll to Security Options and press the trackball. Choose 'General Settings'.
Press the left soft key, then scroll to "Wipe Handheld" with the trackball and press the trackball. To initiate the factory reset, your phones security code may be required in order for the process to complete. Your phone will now be restored to its original settings on leaving the factory.
A hard reset can be achieved with the Pearl in the same way as outlined at Step 3 by removing the battery.
Be aware that resets such as these may erase data, such as contacts, ring tones, pictures, text messages and stored Internet files and emails. Make sure to back up important information beforehand if at all possible. You can obtain software to back up the device to your computer directly from Blackberry Below.
software112.com/products/blackberry-desktop-software.html
Hope this Tip helps. If so please do leave a vote for the solution.
Thanks.
Jan 25, 2011 | Cell Phones
how do i reset my cell phone
To Reset the SCH-A930 Handset, to Factory Default Settings, follow the steps below:
  1. While in standby mode, press the OK button for Menu
  2. Select Settings & Tools, using the navigation keys
  3. Select Phone Settings (5)
  4. Select Security (5)
  5. Enter the lock code, the default password is the last 4 digits of cell phone number, unless it has been changed
  6. Select Reset Phone (4)
  7. Select Yes, using the navigation keys
  8. Press the OK button to confirm resetting the SCH-A930 handset to factory default settings
Dec 17, 2007 | Samsung SCH-a930 Cellular Phone
2,027 people viewed this tip
Top AT&T Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
