Tip & How-To about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Rattle or leaking condensor on Hotpoint WD64
This website has been good to me so I thought I'd post back!
A common problem with the WD64 washer dryer is the condensor working itself loose from the heater box on the top of the machine. This will result in terrifying banging on spin and, if left, screws and rubber seals appearing under the machine. If left longer, as it was with my own, the machine will leak from the condensor to backplate joint at the back of the machine.
The problem is caused by poor fixings at the condensor (the white plastic piece) to the heater (the silver box at the top of the machine).The solution is to remove the condensor, clean it and refit it with new more robust fixings. Hotpoint provide their workmen with a kit of heavy duty bolts, but I did it with a few loose bolts I had. Save all rubber parts as they are riduculously expensive to buy. I had to by the o-ring from condensor to drum backplate and could only get 5 at silly money. If anybody wants one at a good price I'm kolleykibber on ebay.
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
I have water leaking from the dispensing tray, only on the pre wash filling..any suggestions I have a hotpoint washer dryer wd64
Check the level of the machine, may be leaning slightly forward allowing water to leak on that one fill cycle. Lift the front a little by using the adjustable feet and see if it stops.
Feb 16, 2010 | Hotpoint Aquarius WD640 Front Load...
how do i tighten the drum weights on my hotpoint
Remove rear cover, and you will see the concrete weight at the bottom, sometimes the securing nuts work loose, or break off.
There is also a concete weight in the top of the washer as well,so check this as well
Feb 04, 2010 | Hotpoint Aquarius WD640 Front Load...
dryer does not work drum rotates but does not dry on hotpoint aquarius washer dryer model wd64. all other functions operate ok
Probably open circuit heater element, or thermostat/s
Remove top cover, and you will see the heater manifold on the top of the drum.
It is a long aluminium box.
The element and stats are located here..
You will need a meter to test the appropiate components for continuity.
Please rate my solution.
Thanks.
Nov 22, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint WD64 Washer Dryer
Common causes for this are kinked drain hose or clothing, like panties or socks, caught in the pump suction hose. Why, I've even heard of bra wires getting loose and getting stuck in that hose, collecting all sorts of gookus and pinching off the flow of water to the pump. Lay the washer on its side(If possible) and clean out the hose. If it still doesn't work then its time to get a new pump assembly. Good luck!
Jul 15, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius Washer dryer WD64 Not Heating Wash Water
hi pw82,
its seems you're doing your home work. that cylindrical part is the thermostat itself. it should have a resistance in the range of kilo ohms. around 10 kohm to 25 kohms. you can try to change the range of your testing equipment so that you could be sure that te thermostat is really open circuit.
if there is no resistance, then that is the problem. if there is resitance in the kilo ohms range then it could still be ok and you need todo some further testing.
you can check for voltage presence at the terminlas of the heater. if there is no voltage then it could be the relay on the power board that supply voltage to the heater.
or the board itself.
i hope i was able to help..please rate me..tnx
drcool299
Jul 11, 2008 | Hotpoint Aquarius WD63 Front Load...
2,503 people viewed this tip
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
