Tip & How-To about Frigidaire ATF6000ES Front Load Washer
Pumps breaking or clogged and leaking drums
Ever since these washing machines came out the pumps have been an issue. This is true with just about all of the front loading washing machines but more so with the Frigidaire models. I worked for Sears for years as a home repair technician and one of the biggest things that I ran into was these pumps getting stopped up with change, socks, and even under ware. If you want to extend the life of your machine and the pump, simply check to make sure your pockets are empty before starting a load. After every load run your hand through the baffle to make sure that there are no socks or change left in it. These things get sucked into the pump in no time at all.
There is one service call I can remember where I pulled out a good 30 dollars in change from the pump on this man's washer. He couldn't figure out why it hadn't been draining and he was in awe when I found all the change that he had lost over time.
It's simple though and it only take a second to do and it will save you time and a headache in the long run.
One other tip for this model is do not over load these machines. I know that the sales people tell you that you can fit 20 pairs of jeans in these or 15 towels. That couldn't be further from the truth. The result is the rear bearing going bad and the seal between the drum leaking. It costs a fortune to repair and makes a huge mess when it leaks.
Keep the loads to a minimum if possible. I don't mean just put a couple of things in but just make sure you only fill the drum 3/4 full. That is a safe sized load.
Frigidaire ATF6000ES Front Load Washer Logo
Hello, I have the LG Washing Machine Model WM1832CW and I'm having drain issues. The machine itself wont drain the water out. The water remained in the machine. Please advised on what I need to do in order to fix this.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 26, 2011 | LG WM-1832C Front Load Washer
It is not spinning now.
Depending on the make and model top loader or front loader, the most common issues are the lid switch or door lock safety interlock, or the pump filter is clogged and need cleaned. Let me know what machine you have and I can go from there.
Jan 27, 2011 | Washing Machines
I have a top loading Maytag Neptune TL that will not drain. When you start the machine it runs for a few minutes & then shuts off and the time on the screen freezes. I think there is possibly an issue with the drain pump? Is there a way to see if it is clogged?
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Jan 05, 2011 | Maytag Neptune FAV6800AW Top Load Washer
My GE Profile Prodigy WPSE4200A Washer does not spinning for drying and it smells like burning rubber. But it does aggitate for washing. It is a belt issue or could be some electronic device issue?
heatman101
Oct 03, 2010 | GE Profile Prodigy WPSE4200A
kENMORE wASHING mACHINE
if its a front loading washer.. check the filter.. we had this issue with our GE profile front loader.
Nov 25, 2007 | Washing Machines
2,684 people viewed this tip
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
