Tip & How-To about LDK-Productions Impossible Quiz deluxe
What are all the answers
1. LOL 2. literally click on 'the answer' 3.third question box push 'A' 4. bottom right dice 5.green box with YES 6. normal traffic light 7. click the 7 in the level 8.2x 9. it clicks 14 times- 14 10.point of the "i" 11.first button 12.phone will vibrate twice-"brr brrrr" 13.wait til button changes 14.5th letter of "the alphabet" L 15.bottom right 16. click on them then click the add 17.robot 18.a walk 19.notebook 20. choose paper 21. click on any number 1 (level 2'1' or 1 on bomb countdown) 22.here 23.certainly 24.thundershock 25.9 26.im your father 27.east 28. arm on stickman 29.ok 30.ok 31. show then repeat left to right 32.b 33.you look fruity 34.stone 35. literally click "the biggest" 36.9 37. a book 38.two 39.blue-red-green-red 40. 42 41. move over the words " A SKYSCRAPER" 42.brown 43.toe 44. CAREFULLY click the button then go on will appear 45.A 46. click on the lives 47.9,31,44 48.click arnold 49.knife 50.ear 51.52 52. wait til it says PUSH 53.LEO 54. the star on the right 55. +1SKIP 56.zero 57. no- no paths leads to the exit 58. Click black-then green-loose a life making it yellow-loose another life making it red 59.15th october 1582 60.turn sideways 61.of course 62.6 63.red+blue+yellow 64.255,128,0 65.0,1,3,7,22 66.click the face 67.all 68.FIX 69.u=R*I 70.find the differences (look closely to lines) 71.a fruit 72.snub icosidodecahedron 73. 37th 37 74. circle eye confuse it 75. move 7 76.thimblerig 77.2 78.donald duck bonnet 79. 12 80.-51 81.pattern looks like an umbrella 82.backwards Z 83.press and move away finger to each answer box 84.press and hold the button says "Dont click!"
LDK-Productions Impossible Quiz deluxe Logo
wiring MSI ms-7641
http://www.msi.com/product/mb/760GM-P34--FX-.html
http://www.msi.com/product/mb/760GM-P34--FX-.html#/?div=Manual
Under the Download subheading click on the blue -
M7641v4.0.zip
Click on the 'country' name nearest yours.
(U.S. is a country, the others Europe and Asia are continents)
A small window will come up -
Opening M7641v4.0.zip
Make SURE there is a Green dot in the small circle, to the left of Save File.
IF not; click in the small empty circle to the left of Save File.
Go below in the window, and click on - OK.
A small download window will come up.
Allow the file to download all the way, then DOUBLE-click right on the file name.
(Yellow folder icon with zipper on it, and M7641v4.0.zip next to it)
In the next small window go to the far left, and click on -
Extract all files.
At the bottom of the next 3 small windows, click on Next, Next, and Finish.
In the last small window DOUBLE-click right on the file name -
7641v4.0(G52-76411X9)(760GM-P34_760GM-P24_760GM-P2...)
There is your motherboard manual in PDF file form.
(Zip file.
A Zip file is used to send large amounts of information more easily.
It is a Compressed file.
You need to 'unzip' it, or decompress it )
(Adobe Reader uses PDF files)
The Adobe Reader page number box is at the Top, to the right of the Down Arrow.
When I refer to a page it is for that page number box.
Clicking on the Zoom In icon at the Top ( + ) Increases the view size.
Clicking on the Zoom Out icon ( - ) Decreases the view size.
The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the Main wires go to, is the Front Panel header.
Example; Front Panel header pinout:
The Front Panel header is two headers on this motherboard.
Go to Page 11.
Here at the Bottom/Right of the motherboard you see the 6 SATA connectors; all of them Black in color.
To the immediate Left of them, and situated Horizontally; is JFP2.
Junction Front Panel 2.
Two rows of pins.
To the immediate left of JFP2 is JFP1.
It is also situated Horizontally.
Two rows of pins.
JFP1 has two rows of contact pins. 4 across the Top, 5 across the Bottom.
The Top row is numbered EVEN. The Bottom row is numbered ODD.
Starting on the LEFT side, going towards the Right, Top row;
Pins 2, 4, 6, and 8. There is NO Pin 10.
Starting on the LEFT side, going towards the Right, Bottom row;
Pins 1, 3, 5, 7, and 9.
A) Pins 1 and 3 are for the HarDDrive activity LED light.
Pin 1 is for the Positive wire.
If the HDD LED is dim when the Harddrive is active, switch the wires around.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
C) Pin 9 is N/C. Not Connected. This is reserved for the factory. Probably a 5 Volt (DC) test point.
D) Pins 2 and 4 are for a Power On LED light, and TWO wire.
Pin 2 is for the Positive ( + ) wire.
If the PWR LED is dim when the computer is on, switch the wires around.
E) Pins 6 and 8 are for the Power On switch.
F) There is NO Pin 10.
Junction Front Panel 2. (JFP2)
The Top row has 4 pins, and they are numbered EVEN.
The Bottom row has 3 pins, and they are numbered ODD.
Pins 1, 3, and 5. There is NO Pin 7.
A) Pins 1, 3, and 5 are for a THREE wire Power ON LED light.
This type of LED light is a dual color LED.
In the past, and one example; it may have been used for computers that had Turbo Mode, and Normal Mode.
Turbo being Green, Normal being Yellow.
(Which was a bunch of hooey.
Turbo Mode was the Normal mode, and Normal Mode was a slowed down version)
Pin 1 is for the Negative ( - ) wire. Also can be said as the Ground wire.
Pins 2 and 3 are for the power wires, (Positive + ), and each color.
(Example:
Pin 2 for the Yellow side of the dual color LED, and Pin 3 for the Green side of the LED.
Light Emitting Diode. So stating LED -> light is kind of redundant)
B) Pins 2, 4, 6, and 8 are for an internal speaker.
Used to hear BIOS Beep Codes.
If there is something you do not understand, that you need for connecting cables, and peripherals; post back in a Comment.
(A Harddrive, and Optical Drive, are also Peripherals. Not just the Mouse, Keyboard, Printer, Monitor, etc)
Regards,
joecoolvette
Mar 04, 2013 | MSI Computers & Internet
power LED and other connection diagram for MSI 7142 motherboard
MSI Support > K8MM-V motherboard (ms-7142) > Main Support page,
http://www.msi.com/product/mb/K8MM-V.html
Hover your mouse cursor on the Download tab.
(Overview / Specifications / Download / Support / etc)
In the drop down list click on - Manual
Underneath the Download subheading click on the blue -
M7142v.1.0.zip (2005-09-07)
(U.S. is a country. Europe and Asia are continents)
Opening M7142v1.0.zip
Make SURE the small circle to the left of Save File, has a Green dot in it.
Now go below in the small window, and click on - OK.
Allow the file to fully download, then DOUBLE-click right on the file name. ( M7142v1.0.zip)
Extract all files.
In the last small window DOUBLE-click right on the file name.
(Next to the red Adobe PDF icon)
There is the motherboard manual in PDF file form.
You can go page by page, to the page you want, using the Down Arrow; or if you know the page you want you can do this,
1) Put your mouse cursor in the page number box at top.
Left-click once. Anything in the page number box, is now highlighted in blue.
2) Type the page number.
3) Press the Enter key.
A) Go to Page 5 - Layout.
The area of contact pins on the motherboard, that the Main wires from the Front Panel go to, is the Front Panel header.
On your motherboard there are two.
JFP1 and JFP2.
Junction Front Panel 1 and Junction Front Panel 2.
JFP1 is on the Right side of the motherboard, down in the Bottom/Right corner.
It sits Vertically on the motherboard.
Two columns of contact pins.
5 on the Left side, 4 on the Right side.
Go to Page 14 - Front Panel Connectors: JFP1/JFP2
The pins on the Left side are numbered ODD.
The pins on the Right side are numbered EVEN.
Starting on the Top/Left side, coming down;
Pins 1, 3, 5, 7 and 9.
Starting on the Top/Right side coming down;
Pin 1 is for the Positive ( + ) wire.
If the HDD LED is dim when the harddrive is active, switch the wires around.
This is reserved for the factory. Believe it is a 5 Volt (DC) test point.
D) Pins 2 and 4 are for the Power On LED light.
It is for a TWO wire Power On LED light.
The JFP2 header is to the Left of JFP1.
It is situated Horizontally, and close to the bottom of the motherboard.
Two rows of pins.
3 pins on the Top row, 4 pins on the Bottom row.
The Top row is numbered ODD.
The Bottom row is numbered EVEN.
Starting on the Right side, going towards the Left; Top row,
Starting on the Right side, going towards the Left; Bottom row,
A) Pins 1, 3, and 5 are for a THREE wire Power On LED light.
I assume Pin 1 is for the Negative wire ( - ), and Pins 2 and 3 are for the two Positive wires.
It's for a dual color Power On LED light.
Example: Turbo Mode has a Green light, Normal Mode has a Yellow light.
Internal speaker is used to hear the BIOS Beep Codes.
For additional questions please post in a Comment.
[Thought you may want the motherboard manual, too]
Regards,
joecoolvette
Mar 04, 2013 | MSI K8MM-V Motherboard
how to wire trailer plug
hope this helps
6 pin socket
6 pin plug
7 pin socket
7 pin plug
5 pin socket
5 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
12 pin socket
12 pin plug
small 6 pin round plug & socket
1 tail, clearance - brown
2 left hand turn - yellow
3 right hand turn - green
4 stop - red
5 electric brakes - blue
6 earth - white
small 7 pin round plug & socket
1 left hand turn - yellow
2 reverse - black
3 earth - white
4 right hand turn - green
6 stop - red
7 tail, clearance, side markers - brown
roundskt.jpg round socket
large 5 pin round plug & socket
3 earth - white
5 right hand turn - green
6 stop - red
large 7 pin round plug & socket
2 reverse - black
3 earth - white
6 stop - red
7 pin round heavy duty plug & socket
1 earth - white
2 left hand rear , clearance and marker - black
3 left hand turn - yellow
4 stop - red
6 right hand rear , clearance and marker - brown
7 reverse/auxilary - blue
7 pin flat plug & socket
2 reverse - black
3 earth - white
6 stop - red
7_flatsocket.jpg flat socket
12 pin flat plug & socket
2 reverse - black
3 earth - white
6 stop - red
8 battery supply - orange
9 auxiliaries - pink
10 earth - white
11 rear fog lamp - grey
12 auxiliaries - violet
Feb 02, 2013 | 2004 Toyota RAV4
need image of jumper settings for l7s7a2 rev 1.1 motherboard
Elitegroup Computer Systems (ECS) Support > ECS L7S7A2 > Main Support page,
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?CategoryID=1&DetailID=267&MenuID=24&LanID=0
Click on Download.
(Features /Specification / Download / Support / FAQ / etc)
Click on Manual.
(Driver / BIOS / Manual)
Scroll down a little, click on the country name nearest yours, next to the Green Down Arrow.
A small window will come up on the right -
Opening l7s7a2_eng11a.zip
Make sure there is a Green dot in the small circle, to the left of - Save File.
If there isn't; left-click in the empty circle to the left of Save File.
Now go below in the window, and click on OK.
A small window will come up on the left.
In the next small window click on - Extract all files, to the far left.
In the next three small windows click on Next, Next, and Finish.
Finally in the last small window, DOUBLE-click right on the file name, next to the red Adobe PDF icon.
(L7S7A2_en...)
There is the motherboard manual, and the jumper settings.
IF, you cannot open this Zip file, suggest go to 7-Zip, download, and install. It is a free 'un-zip' program.
[ A Zip file is used to send large amounts of information more easily.
A Zip file is a compressed file.
You need to 'un-zip it', or uncompress it.
Requires an 'Un-zip' program.
WinZip usually comes with Windows, but may only last so long, because it is a trial version.
7-Zip is one of the free unzip programs, NO trial.
I use it ]
[NOTE*
I DOUBLE-clicked on the file name - L7S7A2, and a warning 'Squawk Box' came up from Microsoft.
Click on Run. It is OK I assure you.
[ Small primer;
Microsoft assures users that the program they are about to use, is free from Malware. (Virus, spyware, etc)
To do this they check the program out, and certify it to be OK.
This cost $$$$$$ for the software manufacturer.
Costs for the main program check, and EACH time a user downloads the software.
This = NO to most software manufacturers.
Most of the time the software is free, WHO in their right mind is going to pay each time a user downloads it? I wouldn't.
Also if I am a reputable software company, or pre-built computer company, I wouldn't either. ]
IF, somehow you cannot download the motherboard manual:
Motherboard oriented as it sits mounted in the computer case;
Processor to the Top, Ram Memory slots to the Right, 5 white PCI slots to the Bottom;
1) To the Left side of the Processor socket is a jumper.
FIDJP1
CPU (Processor) Ratio Selector
(Multiplier)
Two columns of 5 contact pins.
Contact pin on the Bottom/Right is Pin 1.
Pins on the Right side are numbered ODD.
Pins on the Left side are numbered EVEN.
Starting on the BOTTOM of the Right side, going towards the Top;
Starting on the BOTTOM of the Left side, going towards the Top;
Pins 2, 4, 6, 8, and 10.
Jumper on pins;
A) 1 and 2 - BIOS checks the Processor out, and automatically sets the Multiplier. (CPU Ratio Selector)
B) No jumper used -> 10.5
C) Jumper on pins 9 and 10 -> 6.5
D) Jumper on pins 7 and 8 -> 8.5
E) Jumper on pins 7-8, and 9-10 -> 12.5
F) Jumper on pins 5-6 -> 9.5
G) Jumper on pins 5-6, and 9-10 -> 5.5
H) Jumper on pins 5-6, and 7-8 -> 7.5
I) Jumper on pins 5-6, 7-8, and 9-10 -> 11.5
J) Jumper on pins 3-4 -> 10.0
K) Jumper on pins 3-4, and 9-10 -> 6.0
L) Jumper on pins 3-4, and 7-8 -> 8.0
M) Jumper on pins 3-4, and 7-8, and 9-10 -> 12.0
N) Jumper on pins 3-4, and 5-6 -> 9.0
O) Jumper on pins 3-4, 5-6, and 9-10 -> 5.0
P) Jumper on pins 3-5, 5-6, and 7-8 -> 7.0
Q) Jumper on pins 3-4, 5-6, 7-8, and 9-10 -> 11.0
The JP1 jumper is to the Right of the bottom white PCI slot.
(No.5 PCI slot)
3-pins going across in a row.
Pin all the way to the Right; is Pin 1.
Starting from the Right side, going towards the Left;
Pins 1, 2, and 3.
Turn computer OFF.
Put a jumper cap in Pins 2 and 3 for 5 seconds.
Remove the jumper cap, place back on pins 1 and 2.
Resets CMOS memory.
Just in case you are referring to the Front Panel header;
The area of contact pins on the motherboard, that the main wires go to, is the Front Panel header.
The Front Panel header is to the Right of the CMOS battery, and is located next to the right outside edge of the motherboard.
Two columns of pins.
IF, I am reading this correct; 5 pins on the Right side, 4 pins on the Left side.
Starting on the Bottom of the Left side, going towards the Top;
A) Pins 1 and 3 are for the HarDDrive activity LED. (Light)
Pin 1 is for the Positive connection.
C) Pin 9 is N/C. Not Connected. It is Reserved. (Probably 5 Volts for the factory to test )
D) Pins 2 and 4 are for the Power On LED. (Light)
Pin 2 is for the Positive wire.
Regards,
joecoolvette
http://www.ocworkbench.com/2003/ecs/l7s7a2/l7s7a2-1.htm
Nov 11, 2012 | EliteGroup L7S7A2 Motherboard
list answers to the impossible quiz
Question 1: Four
Question 2: No, but a tin can
Question 3: K.O
Question 4: THE ANSWER
Question 5: Right click then move over then click, or move off the screen.
Question 6: Shallots
Question 7: An elephant
Question 8: Yes!
Question 9: THAT ONE (top right)
Question 10: Dentures
Question 11: n
Question 12: The dot above "I"
Question 13: F'TAANG
Question 14: Torch
Question 15: HORSE
Question 16: H
Question 17: 17.
Question 18: Hammer
Question 19: Blue, Orange, Green, Green, Yellow (BOGGY)
Question 20: Seal!
Aug 15, 2011 | Video Game Consoles & Games
11,424 people viewed this tip
Top LDK-Productions Apps Experts
Are you a LDK-Productions App Expert? Answer questions, earn points and help others
