Tip & How-To about Lenovo Computers & Internet
On lenovo pc's always check memroy space and the software versions to help the pc run beter
Alway's check the memory and the software versions to help the pc run good
Computers & Internet Logo
installing adobe acrobat pro 6 to windows 7
This is an old version of Acrobat that was written for NT, Win2K and XP. Due to changes in the OS, it's hard to get the program to install in Windows 7.
Which version of Win7 do you have? (32-bit or 64-bit and Home Premium, Pro or one of the other variants) Since you indicated this under the Dell Dimension E521 with 1 GB of memory, I'll guess Win7 Pro 64-bit. (This uses the 64 bit CPU) You can check by clicking Start > Control Panel > System and Security > System. If the Windows version ends with x64, it is the 64-bit version. Otherwise, you have the 32-bit version.
Under the 64-bit OS, you need one of the following workarounds: a second computer, a dual boot computer or a virtual computer running an older version of Windows. If your hardware supports virtualization, this might be a good bet if you can add memory to computer. With Win7 Pro or Ultimate, you can download and install Virtual PC and XP mode from Microsoft and run XP for free. Then install Acrobat in XP mode as if it were your only machine. (Note: the Virtual PC requires a share of your total memory and doesn't give it back to the main computer while it is running.)
The other methods listed require a licensed version of an older Windows OS.
If you have the 32-bit version of Windows 7, you can try the compatibility mode. Right click on the installer and choose Properties. In the compatibility tab, check always run in the compatibility mode and select an older version of Windows. Then click Apply to save the changes and then click OK. Then right click again and choose Run As Administrator. You may have to repeat the compatibility mode changes for the program itself.
You may want to consider upgrading to a Windows 7 compatible version of Acrobat. The current version is Version X.
I hope this helps.
Dec 26, 2011 | Dell Dimension E521 AMD Athlon 64 X2...
i have a HCL P28 laptop & my my laptop start become so late, & many time it does not start so plz help me...
) Delete all unwanted data from Drive C.
2) Delete all data that you have copied from Drive C to External HDD
3) Open My computer and go to Tools---> Folder Options---->Click on View Tab----> Check 'Show hidden files and folders' and select OK.
4) Go to C:\Documents and Settings\Administrator\Local Settings\Temp and Delete everything that you see inside Temp Folder
5) Go to C:\WINDOWS\ here you will find folders like $hf_mig$, here you will have to Delete all the folders starting and ending with $ sign.
Go to 'Start' and then Run
write "msconfig" inside Run tab and press 'enter'
inside the 'System configuration utility' window click on 'startup' tab then uncheck all the applications except your current antivirus and press apply then 'ok' and then 'exit without restart' option.
Now right click My Computer and go to properties tab.
click 'Advanced' tab then under performance menu click on 'settings'
go to 'Advanced' click on 'change' and increase your virtual memory to 2048 in both spaces.
Now restart windows.
There are many things that might cause your PC to run slowly. It could be a fragmented disk; fragmented registry; a virus, Trojan, or spy ware; high CPU and/or utilization due to too many programs running; high disk I/O; or something else.
To check your CPU and memory utilization, run Task Manager. You can start Task Manager by pressing CTRL+ALT+DEL and then clicking on the Task Manager Button. In Task manager, click on the Performance tab and check CPU Usage and PF Usage. PF Usage is an indicator of memory usage. If one or both of these is high, click on the Processes tab, and sort the columns by CPU or Memory to see what processes are consuming the resource. If you are not sure what the process "Image name" is for, Google the name and you should find what the process is for.
If your CPU and memory usage are reasonable, then you may have a different issue. Even if you running anti-virus software, it may be beneficial to scan your PC with another scanner to check for viruses. No anti-virus software is 100% perfect at catching everything. Here are a few good free online virus scanners that you can run to check your PC:
http://security.symantec.com/sscv6/home.asp?langid=ie&venid=sym&plfid= 23&pkj=RRJEDTKJBTVISBYWWYP
http://onecare.live.com/site/en-us/default.htm
http://www.eset.com/us/online-scanner
http://www.pandasecurity.com/homeusers/solutions/activescan/
An excellent free utility for overall system maintenance is Advanced System Care Free ( http://download.cnet.com/advanced-systemcare-free/3000-2086_4-10407614 .html ). I use this utility on a regular basis.
You should always run anti-virus software. There are several very good, free, anti-virus products available. One good source to read editor and user reviews, and safely download anti-virus software, is http://download.cnet.com -- search for free antivirus software. In addition to the reviews, you can see how many people are downloading the software, which is another good indicator of how popular it is.
I have used AVG Free ( http://download.cnet.com/avg-anti-virus-free/3000-2239_4-10320142.html ) , and Avast Free ( http://download.cnet.com/avast-free-antivirus/3000-2239_4-10019223.htm l ). Both are very good, and completely free. At present I am using Avast on all of my home computers.
I have heard good things about Avira AntiVir Free ( http://download.cnet.com/Avira-AntiVir-Personal-Free-Antivirus/3000-22 39_4-10322935.html ), and it has good ratings, but I have not personally tried it.
In addition to Avast or one of the other free anti-virus software packages, I also run Ad-Aware ( http://download.cnet.com/ad-aware-free-internet/3000-8022_4-10045910.h tml ). Ad-Aware is a free anti-malware, anti-spyware package.
Aug 02, 2011 | Computers & Internet
my board is dell made model D865 with 2.6 GHZ processor but my board is not working properly its very slow speed for installing any operating program
1) Delete all unwanted data from Drive C.
6) Empty Recycle bin and restart the PC
Jul 29, 2011 | Dell Computers & Internet
Acer Aspire 5532 freezes on startup Acer screen. I can't go into safe mode at all. Sometimes if I'm lucky it will start normally.
After restart login to windows and do the following
If you feel that my answers have helped you getting solution to your problems then please give a vote.
Thanks.
Jul 26, 2011 | Aspire Computers & Internet
To a Hp System ( pentium 4 ) i put a pen drive. Cpu detects and try to install by itself during the process cpu gets Stucked
Just do the following steps and your issue will be resolved.
Thanks.
Jul 07, 2011 | Computers & Internet
2,348 people viewed this tip
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Lee Durbin
Lee Durbin
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
