Tip & How-To about TP-LINK TPLink (TLWA730RE) Wireless Router
Setting up and scanning for wireless
Hi
Page 11 in the user-guide and onwards....that works.
I had so many problems setting this thing up, but finally I entered it via my web-browser, and that worked!!!
TP-LINK TPLink (TLWA730RE) Wireless Router Logo
I'm trying to use my Sharp AR-M355N as a scanner for the first time. I've already made sure it's properly hooked up to the network and have successfully printed to it. I scanned a test page, put in the e-mail address I want to send it to, and upon hitting send it says "NETWORK ERROR. (CE-02) CONSULT YOUR KEY OPERATOR OR SYSTEM ADMIN." I'm afraid I'm a bit lost now...
When scanning to e-mail you would need to enter the details of a smtp server e.g. Gmail, as well as your DNS settings into the photocopier via the web browser. To access the browser, enter the I.P. address of the copier into the web address & this will give you the front page of the copier. To access the network settings you'll need the user name : admin & the password Sharp. Depending on the firmware version the machine must have SSL installed, if it hasn't then unfortunately you will not be able to scan to e-mail. The alternative is to scan to SMB (folder), again this is set up via the web browser.
Hope this helps.
Dave.
Aug 26, 2017 | Sharp AR-M355N Copier
need to down load user guide for motorola droid or have one sent to my home.
Motorola Droid Downloads can be accessed via the Motorola Support Website
Alternatively, you may enter the following in your web browser of choice :
http://www.motorola.com/Support/US-EN/Consumer-Support/Mobile-Phones/Droid+-+USA_Default+US_Loc%253AUS-EN
From this page you will find this and additional downloads available for the Droid as well as other Motorola products. If you are in a hurry, here is the direct link to the Droid User Guide (Adobe Acrobat, or "PDF" format)
http://www.motorola.com/staticfiles/Support/US-EN/Mobile%20Phones/DROID-by-Motorola/US-EN/Documents/Static-Files/DROID_UG_Verizon_68000202474a.pdf
Mar 28, 2011 | Motorola Cell Phones
I want to connect to my modem via my web browser so that I may change it's settings. What do I do?
Hi maxowensnoop,
If you want to change some settings on the modem you can check this manual for your guide.
Thanks for using Fixya.
Feb 04, 2011 | Arris SURFboard SB5101U DOCSIS 2.0 Cable...
The router was reset. So, our AP does not work with it anymore. I reset the AP to restore it to its factory default settings and tried to follow the steps I made before in configuring the AP. but i can't access http://192.168.1.1 so I could not log in to the AP's page where you configure the settings. I remember the last time I configured it, we have entered the mac address of the AP to the main computer unit. But this time I haven't entered it since the main unit is currently unavailable. Is that the reason why I can't access 192.168.1.1? the brand of the AP is encore enrxwi-g. I hope you can help me in here. thanks a lot.
Before you configure this device, note that when the AP is configured through an Ethernet connection, (via RJ45 Network Cable) make sure the manager PC must be set on same the IP network. For example, when the default network address of the default IP address of the AP is 192.168.1.1, then the manager PC should be set at 192.168.1.x (where x is a number between 2 and 254), and the default subnet mask is 255.255.255.0.
Open Internet Explorer 5.0 or above Web browser.
Enter IP address http://192.168.1.1 (the factory-default IP address setting) to the address location. Please refer here to the Latest User Manual for Encore ENRWI-G Page 9 onwards describes the login details.
Hope this Helps!
CreativeTECH
Jan 01, 2011 | Encore WIRELESS LAN EXTENDER
Hope this Helps!
CreativeTECH
Jan 01, 2011 | Computers & Internet
2,134 people viewed this tip
Top TP-LINK Computers & Internet Experts
Martin Murray
Robert
Level 1 Expert
Are you a TP-LINK Computer and Internet Expert? Answer questions, earn points and help others
