Tip & How-To about Onkyo TX-DS696 Receiver
Not responding to remotes
I've owned an Onkyo DS696 receiver for 5+years. Every once in a while (when it was on for a long time?) the receiver would not respond to the remote. At first it could be "fixed" by a simple power cycle. It got worse over the years, and finally the unit would not respond to the remote at all. After reading a post here that made perfect sense, my husband and I opened the unit up, and (even thought the solder at the IR connection LOOKED fine, we resoldered it. (He knows how to do these things expertly). We screwed the unit back together and VOILA! it works perfectly now. Even if you don't know how to solder, if you brought it to a repair shop and told them exactly what the issue was and how to fix it - you can save your sanity and the unit. The solder joint I'm talking about is directly behind the IR on the front daughter board.
Onkyo TX-DS696 Receiver Logo
my display wont work and my remote quit at the same time
for this problem please call to your manufacturer customer suppport for technician to rectify thre problem because it is the internal problem so i advise do not open the cabinet of your channel receiver
Oct 30, 2010 | Onkyo TX-DS696 Receiver
Onkyo TX-DS696. No right channel speaker sound
hello there 2 transistor 1 for the right channel and 1 for the left first thing 2 do is a visual check in good light check for any burn't part or any bulging capacitors if everythink looks ok then check underneath the board for dry joints if then you will need a mulitmeter to start testing components
regards
shasun
May 15, 2010 | Onkyo TX-DS696 Receiver
The remote control dosn't work!
I had to remove the batteries of the remote control.
Having done that, the remote control has been reinitialized and worked again perfectly.
Aug 18, 2007 | Onkyo TX-DS696 Receiver
1,093 people viewed this tip
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
