Tip for B100 Coffee Maker
Keurig B100 Not Brewing Fix
posted on Jun 21, 2007
Burnzy
Burnzy
Rank: Apprentice
Rating: 98%, 30 votes
Symptom: keurig B100 coffee maker not brewing. If your brewer sounds like it should be brewing but little or no coffee comes out, the problem may be a simple malfunctioning check valve, located on the right hand side of the unit under the plastic cover. If the check valve is clogged or fails, water from the tank leaks into the air pump (located just below the valve) disabling the pump.
This happened to my brewer two days ago. I have had this unit for about four years and never had a problem. When I called tech support at Keurig they said "it sounds like the pump is shot", but there was nothing they could do and they would not repair it. Instead of the throwing out my $300 coffee maker I figured I would try to fix it myself.
After 3 hours of tinkering, I found and fixed the problem, so I am passing on the tip. Since 2.5 of those hours were spent diagnosing the problem, the fix itself is pretty simple.
The pump that pushes the water out of the tank located on the right hand side of the unit (I included a photo) has a check valve just above it. On my unit the check valve failed allowing water to enter the top chamber of the pump disabling it. The pump was not damaged it just cannot operate correctly with water in it.
Here is the Fix: Disconnect the check valve and make sure it is operating correctly. Mine was clogged with a small amount of mineral deposits, which was cured by a half hour in a glass of vinegar, and a good rinse. Then disconnect the tubing from the top of the pump and run the unit to allowing the water to escape the pump. Make sure there is no water left in any of the tubing between the pump and the check valve, even the smallest amount will disable the pump again. Reconnect everything and it should work.
Hope this was helpful.
Erik
Comment by Burnzy, posted on Jun 21, 2007
I forgot to add the photo, here it is.
Very Helpful
Was this helpful?
Yes
No
9 people thought this was helpful
Comments
- Dec 13, 2007
BURNZY.....YOU ARE A GOD SEND!! After calling the Keurig Service Center about my B100 Cofee brewer that just suddenly stopped working after a year, and getting nowhere on the phone with tech support, I turned to the internet for technical advice and found your tip. I followed your exact instructions carefully, The photo was extremely helpful, and guess what?? IT ACTUALLY WORKED-MY UNIT IS BREWING ONCE AGAIN!! I really thought I was doomed to trashing the unit which was working fine until it just stopped working for no reason. Thanks again. I will highly recommend the site, and your tip.Thanks to you, I will enjoy another great cup of coffee from my Keurig B 100 brewer. So much for a "shot pump" !! <LOL>
Add a Comment
Insert Link
Can you Help with these Coffee and Espresso Makers problems?
Answer
Only fills 2 oz of water. I cleaned unit with 1 bottle of vinegar, used the pin to clean out the... (More)
Answer
The water pump stopped pumping water and the B60 turned off. I've had it four days. I reset the... (More)
Answer
after pushing start, no water comes through. The machine has been de-scaled and the needles have... (More)
Answer
Where may I purchase K-Cup assembly housing for Model # B30?
Answer
How to use Keurig insert. How much coffee do you put in it?
Describe your problem:
Select a Category:
Insert Link
What is this?
Select
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Small Appliance Repairmen
(866) 240-3413
When onsite service is not an option you can count...
National Appliance Network
(316) 772-7617
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Step 2: Select a product and click on add
I can't find my product
select
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
