Tip & How-To about Nokia N95 Cellular Phone
Nokia Software Updater
Dear updaters, Many of you received the following message when updating their phones "Internal module error". When installing Nokia Software Updater (NSU), very frequently the Microsoft XML4 DLL silent installation crashes. This issue can be fixed by manually registering DLL. Go to Start > Run > enter "regsvr32 C:\WINNT\system32\msxml4.dll" > OK > OK. I hope this helps most of you suffering from this issue.
Nokia N95 Cellular Phone Logo
Cannot receive or send picture messages.
FAQ - I cannot send or receive multimedia messages (MMS ...
www.microsoft.com/en.../faq/?...singleTopic&topi...
Microsoft CorporationI cannot send or receive multimedia messages (MMS) on my Lumia phone. Restart your phone with SIM card inserted, and retry sending a multimedia message ...
messaging - MMS sending and receiving pictures no longer ...
windowsphone.stackexchange.com/.../mms-sending-and-receiving-pictur...
Feb 4, 2014 - MMS sending and receiving pictures no longer working on Nokia Lumia. up vote 2 down vote favorite. In early 2014 I installed "Update 3" (8.0.10517.150) and the "Lumia Black" software ... "Can't send message Try again".
Can't send or recieve picture messages - Windows Central Forums
forums.windowscentral.com/nokia-lumia.../299901-cant-send-recieve-pi...
Jul 30, 2014 - 7 posts - ‎5 authors
I have had several friends try to send me a picture message, and i myself have tried tosend a picture message, and i'm just not able to receive ... Not sending Picture messages
Jul 22, 2013
Not able to receive MMS on Nokia Lumia 920 on AT&T
Jul 1, 2013
Can't receive or send MMS
Jun 7, 2013
Cannot Send or Receive MMS (T-Mobile)
Apr 21, 2013
More results from forums.windowscentral.com
Nokia Lumia 930 - Troubleshooting - You can't receive ...
Jan 12, 2016 | Nokia Lumia 930 Smartphone RM-1045
my nokia 3310c when dowloading applications, after reaching 100% download it shows a message application error.
It means the application installer not compatible with your phone. i.e. the application file is .sisx for Symbian S60v3 which is not compatible with your device. Or the file is broken or outdated.
When you download any application software, make sure its compatible with your phone. Your device can only install JAVA application so you can download application with .jar extension. And choose application with proper size for your screen (128x160 pixels), if its too big, it wouldn't able to be installed too.
Hope this help and if helpful RATE please.
Feb 03, 2011 | Nokia 3110 Cellular Phone
I cannot open messages from Inbox folder. Only able when I open it directly thru new message key shortcut shown on home page/screen once received. So I only get to read the message once and not able to re-open it when I need to.
Hi justinekaizz.......
You Problem is related to virus attack.
Try the following.
*Restore your phone once(To Restore Go to Menu>Settings>Restore Factory Settings>Ok(Default Security code is 12345)>Yes(It takes 1-2mins).
*Scan your phone and memory card from a updated anti virus.
At Last.... if Problem persists.....
You need to flash(format)your phone.
Formatting resets the security code to 12345
(formatting delete all data including messages,contacts,etc... So i suggest you to back up all the files before formatting You can back up file using Nokia PC suit)
To back up your files
*Install the Nokia PC suit
*open Nokia PC suit >Select Back up
To restore Backed up data
*Open PC suit>Tools tab>Restore>Select Restore>select a restore point(restore point is file in which all data's are saved)>Ok and wait for 5-10 mins.
To flash you need
*USB cable compatible with your handset
*A Computer
*Nokia PC suite of your handset
*Internet connection(Min speed 1Mbps)
*Nokia software updater(you can download by using Nokia PC suit)
To flash
*Install the PC suite
*Connect to USB
*Open the PC suit
*Select UPDATE PHONE SOFTWARE(download the Nokia Software updater by selecting this option)
*Install the "NOKIA Software Updater"*Select Update**....(It takes 10-30 Mins)
**Please don't disconnect while updation process
Jan 31, 2011 | Nokia E63 Cell Phone
Have just installed S1500 software and finished the installation but get an error message "Failed to initialize drinver module (0 X 80210019)". What does this mean and how do I proceed? ****
Try the following step :
Pre-Installation Steps
  • Log onto PC with an account that has Administrative Privileges.
  • Disconnect ScanSnap scanner, if connected.
  • Close any open applications.
  • Install ScanSnap Manager, ScanSnap & CardMinder software from the ScanSnap Setup CD-ROM.
    • Upon reboot of the installation you may receive an error message stating, “Failed to initialize driver module.” Please disregard and continue.
ScanSnap fi-5110EOX Vista Update Pack Installation Steps
  1. Download the fi-5110EOX Update Packs (Vista 32-bit Support)
    1. ScanSnap Manager V3.0 – ssv3020up.exe
    2. CardMinder V2.0L10-V2.0L11 – cm2012.exe
  2. Install all two update packs that were downloaded in Step #1.
    1. Reboot is NOT required after each update pack.
  3. Reboot the PC after all three update packs installed completely.
  4. Connect ScanSnap Scanner via USB, open lid, let Windows Vista install the new hardware.
Mar 07, 2010 | Fujitsu ScanSnap Manager
i updated n73 mobile it is not working
hi, i had this problemonce with the n95, i tried re installing the software, it took about 3 attempts but it did work
Jan 02, 2009 | Nokia N73 Cellular Phone
1,871 people viewed this tip
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
