Tip & How-To about Sylvania 6626LG 26 in. LCD Television
HDMI Closed-Captioning won't go away
I bought this television yesterday, bought the HDMI cord and hooked it up through my Comcast digital cable box. Every channel would display closed captioning, despite it's supposed inability to support that function. In order to remove it, we had to turn off the cable box's ability to display closed captioning. To do that, turn off the cable box and hit menu to get to the setup menu. It is there that you will be able to turn off closed-captioning.
Sylvania 6626LG 26 in. LCD Television Logo
trying to hook up my panasonic tc-p50c2 to comcast hd digital cable box and cant get it to work with hdmi cord..nothing is showing
Use only the hdmi cord to hook it up and go to menu on the tv and select hdmi for hook up and you should get a picture. Make sure your cable cord is the only cord running to the cable box , you don't need any other cord.
Feb 09, 2011 | Panasonic TCP50C2 50 in. TV
No sound on NON HD channels
I had the exact same problem on a brand new Insignia 26 " LCD with DVD. Comcast tech was able to fix it by changing the Comcast box diagnostics. Here is what he did. Using the Comcast remote with the TV on - press power, cable, menu in that order. A comcast diagnostic srceen will appear. Select Additional HDMI options, then audio options. Change the audio options to L-PCM. Press power again to exit the diagnostics. That will fix it and you get to use the HDMI cable.
Jun 26, 2008 | Insignia LCDTV26 26 in. Television
turn off closed caption on input(component) on Sharp Aquos 42"
Had this happen on a Comcast box (Motorola DCT 6416 III)
Here's how to fix it:
Turn the cable box off, leave fully connected. Press Menu on the remote
The cable box internal menu will display (Not the Comcast one the Motorola one-- i.e. Display ratios-16:9 etc It's in black and white)
Use the arrows to cursor to the Closed Captioning and toggle to "Disabled" Press Manu again to exit and Voila!
Power the box on an have at it
Apr 10, 2008 | JVC HD-61Z575 61" Rear Projection...
closed caption problem
I had the same issue... here's what I did.  If power off your cable box, then press the menu button, there's a selection to enable or disable Closed Captioning.  This works for both HD series Motorola boxes Comcast offers, at least in the Minneapolis/St. Paul area.  Hope this helps!
Evan
Feb 17, 2008 | Toshiba 42LX177 42 in. LCD HDTV
ilo 42" plasma tv
Go the the settings on the cable box. look for output resolution, then change it to 1080i and 720p. now turn the box off and back on your tv will now display the input of wither 1080i or 720p depending on the hd channel your watching.
Dec 26, 2007 | Televison & Video
2,047 people viewed this tip
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
