Tip & How-To about All-Pro Kerosene Garage Shop Heaters - All Pro PK115T Forced Air Kerosene Space Heater
All pro 155 kerosine heater
I have pro 155 kerosine hewater when i plug it in he atart whork for 2 mins and stop pls help
All-Pro Kerosene Garage Shop Heaters - All Pro PK115T Forced Air Kerosene Space Heater Logo
yardman seris 155 42 inch cut will only run for 30 sec to 1 min then stops why
try and run it with the fuel cap loose the vent in the cap could be plugged
Jun 04, 2012 | Garden
look below
make sure air and fuel filter are clean.Set pump pressure to mfg set pressure after two minutes of operation
Feb 26, 2009 | All-Pro Kerosene Garage Shop Heaters - All...
pro 155 kerosi ne heater
Check your fuel and air lines for leaks, typically it's the CAD flame sensor but if you have already replaced it try checking the high heat limit switch. It looks like a thick watch battery just behind the combustion chamber, take it off and hold a lighter under it. If it's working properly you should hear a faint click when it shuts off, no click then it's bad.
Jan 15, 2009 | All-Pro Kerosene Garage Shop Heaters - All...
681 people viewed this tip
Top All-Pro Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
T bone 1963
Are you an All-Pro Heating and Cooling Expert? Answer questions, earn points and help others
