Tip & How-To about Asko W6021 Front Load Washer
Asko W6021 would not fill with water
Our W6021 front has had a couple of instances where it would not start the fill cycle as usual. Normally it would be switched on,the relay would operate and the water would begin to enter the bowl. We tried a number of things including checking the hose and inlet filter for blockage. We then checked the outlet drain pump trap and found a coin and a drill bit lodged in the entry hole to the trap. Once the foreign objects were removed ,the machine operated as normal once again. I will be very careful in future to empty my pockets of metal things.
Asko W6021 Front Load Washer Logo
Asko w6021 started to fill with water and then shorted out the power any suggestions?
not much help sorry but is possibly the motor shorting, try turn the drum a little before you reconnect and see if it still shorts. I have had an element rupture and therefore be soaked in water and thus causing the short. Sorry I cant help more
Mar 04, 2013 | Asko W6021 Front Load Washer
Asko washer w6021 doesn't work. I've checked
See whether water is flowing into the wash machine. Then the door close switch.
Mar 28, 2010 | Asko W6021 Front Load Washer
Asko Washer W6021 Problem
CHECK THE BRUSHES ON THE MOTOR, FOR BEING WORN DOWN!
REGARDS........TREVOR. FLEETWOOD UK.
Mar 09, 2009 | Asko W6021 Front Load Washer
Asko W6021 won't start
change the carbons theres nothing wrong with the board
Jul 30, 2008 | Asko W6021 Front Load Washer
Asko W6021 Front Loader Washer Problem
the carbon brushs in the motor need replacing,on the w6021 the fault you get is a clicking sound when you press the start button.
Nov 01, 2007 | Asko W6021 Front Load Washer
1,491 people viewed this tip
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Joseph Hoffmann
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
