Tip & How-To about Panasonic Palmcorder PV-DV103 Mini DV Digital Camcorder
Recording or playing back
For all of you who have this problem. You can't record or playback anything and your power light is blinking. Just turn it on and off on and off. I did this for about 5 minutes. Just turning off and on and then trying to play or record something then took out the tape and blew with a duster for cleaning your keyboard and that worked. This has happened before and well that worked for me. Hope it helps anyone outthere.
Panasonic Palmcorder PV-DV103 Mini DV Digital Camcorder Logo
red light blinking
i was filming, and i tripped and my gl2 hit the ground. it hit the battery kind of hard and now it wont work properly. now when i turn it on, the power light blinks red or green, depending on playback and recording mode. i want to know how i can fix this.
Dec 18, 2008 | Canon GL2 Mini DV Digital Camcorder
Problem with Playback and Record on camera
The fix is really easy and costs nothing, just 10 minutes of your time!
*I fixed mine (twice) this way*
Turn the cam over.
remove all the screws holding the dark plastic bottom on the camcorder, remove it carefully.
Now you will see the ribbon cables, VERY GENTLY, wiggle them from left to right (about 1mm each way), then push them in.
Test by putting your battery back on and see if it holds a tape, or plays without blinking and switching off - you will be happy.
The fault is simply that one cable (I can't tell you which one) becomes loose over time, so it just needs to be pushed back in and the condensation error and/or the door closing problem go away!
A lot of folks are buying cams off eBay like this as it's such a simple repair!
Good luck - please help others - post back if it works!
Sep 08, 2007 | Panasonic NV-DS60 Mini DV Digital...
when the red light flashes the camera either has a fault with tape mech or the lens unit. This should be checked by a panasonic technician.
Jun 15, 2007 | Panasonic PV-DV103 Mini DV Digital...
1,236 people viewed this tip
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
