Tip & How-To about Bugaboo Frog - Denim Stroller
Bugaboo Denim stroller
If you get a flat tire take it off and bring it to a bicycle shop for repair. They will be more than qualified to fix it and it wont take a whole week to get it back. When cleaning upolstery always use cold water and a very mild soap like Woolite. Do not leave stroller in direct sun when not using it.
Bugaboo Frog - Denim Stroller Logo
flat tire
A bicycle repair shop should be able to tell you the tube size if you provide the tire size markings on the sidewall of the tire.
Apr 07, 2014 | Bianchi Milano
My jeep jogging stroller has a flat. Do I need to
Replacement tube may be more beneficial even though the fix/patch may be cheaper. If you live in an area that have varying climate, the patch along with the repaired tube can expand and contract and may cause small leak if not repaired properly.
Otherwise I would get the right size tube, most jogging strollers are either 12" or 16" tube inside and can be bought from your local bicycle store. With that, you'll need bicycle tire levers which can also be bought at the bike shop. Just about any type of tire levers will do. Of course I'm sure your bike shop can do this for you to possibly for free with a purchase of replacement tube!
Oct 27, 2009 | Jeep Liberty Limited XT Urban Earth Jogger
unrepairable inner tube
True Goo inner tube sealant! Go to a bicycle repair shop with your stroller, and honestly, have all the tires shot up with this goo and then pumped up to your desired firmness...
I have a different jogging stroller, but I know the Maxi Cosi's Mura has the same air pump access as other bicycle tires like my jogger does. I kept getting flats, and this goo has kept my tires firm for 6 years now, I used to have to bring along a pump, but never again after this repair, it plugged up a small leak for one of my tires that kept going flat quickly and keeps the others from the eventual softness that was recurring.
Aug 23, 2009 | Maxi-Cosi Baby Gear
Bugaboo Frog Flat tires
Any bicycle shop will be able to repair the tires for you.
Apr 06, 2009 | Bugaboo Frog Stroller
flat tire
You can repair the tube the same way as you would a bicycle tire. If you don't want to do it yourself you can bring it to any bike shop.
Nov 08, 2007 | Quinny ZAPP Stroller
544 people viewed this tip
Top Bugaboo Baby Gear Experts
Jennifer Rock
Jennifer Rock
Jerry Greenberg
Jerry Greenberg
Are you a Bugaboo Baby Gear Expert? Answer questions, earn points and help others
