Tip & How-To about Canon NP 6085 Copier
On the older Canon 6085 copier
From my understanding there are two types of NP 6085 copiers. To get into the service menu on the older type you will need to open the doors above the 2 paper trays and look on the right hand side for a small hole. Once you find the hole insert a bent paper clip into the hole to depress a switch. If done correctly you will see an S in the upper left corner of the display. Then hit the following *4*. that will put you into service menu.
Canon NP 6085 Copier Logo
0107 and 0115 code jam np 6085
This code don`t exist in the Cannon np 6085
Sep 01, 2009 | Canon NP 6085 Copier
i have canon 6085 very bad print and code error e012
Hello sir; Looks like the drum motor have problem, open back cover find out drum motor and look around have any gear broke if everything fine then replace motor that is necessary.
Jun 13, 2009 | Canon NP 6085 Copier
e 003 error code on power up
The code error is:
E003: After the temperature of the upper fixing roller has reached 180C, it drops to 100C or less for 5 sec or more.
Jan 09, 2009 | Canon NP 6085 Copier
CANON 6085 PROBLEMS
Was it working before the problem? Did the user have a paer jam? You may have a jammed pice of paper in the paper feed unit
Jun 08, 2008 | Canon NP 6085 Copier
1,537 people viewed this tip
old marine
old marine
