Tip & How-To about Microsoft Xbox Console
Problems with xbox reading disc?
Two options either buy your self some laser clearner
or buy your self a new laser lens it will probably end up cheaper to get a new laser lens, But if you cant fit the lens then you stuck with using the cleaner.
Microsoft Xbox Console Logo
Toshiba SD-24VLSL won't read DVD
The laser pickup is at the end of life, far cheaper buy a new player.
May 08, 2012 | Toshiba Televison & Video
I have a DP-R6080 or DP-R5080 5 cd changer player. Its probably 10 years old or so but recently the CD have begun to skip. Its not the CD because the new ones skip and they play fine on a single player that I have. How can this problem be fixed.
The trouble lies in the laser pickup assembly, the only option you can try is buy CD cleaning kit and follow the instructions, the kit will remove any dirt that might have collected on the laser lens, If it works you will get more usable time out of the machine. The fact that you got 10 years is much better than the average, overtime the laser gets weaker until it can not track properly, so! if the cleaning fails it is far cheaper to replace than to repair.
Mar 15, 2011 | Kenwood Audio Players & Recorders
my dvd player has a good dvd in it but it says it is loading and or no disc what is wrong with it
The problem is in the laser pickup assembly, overtime the laser becomes weaker until it can not read the disc. The only option is to gently clean the laser lens with a Q-tip and rubbing alcohol and allow several minutes to dry, if this fails, cheaper to buy new than repair.
Mar 13, 2011 | Venturer PVS8380 Player
CD drive not spinning up, why?
The Laser Pickup Assembly is the problem, usually caused by a weak laser pickup or a defective pladder motor that spins the cd's, one possible solution is clean the laser pickup lens with a Q-Tip and rubbing alcohol, if this fails the entire assembly must be replaced or buy new the cheaper option.
Jan 08, 2011 | Marantz CD-17 CD Player
657 people viewed this tip
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
