Tip & How-To about Samsung LE40R72BDX 40 in. HD-Ready LCD Television
Blu ray
Plug blu rays in hdmi port 2 and plug it's sound
Samsung LE40R72BDX 40 in. HD-Ready LCD Television Logo
my blue ray / dvd player surround sound won't stay on when I have it on AUX for the TV. Model # SA-BTT195 (?)
What do you have plugged into the AUX port?
Have you tried HDMI 2 some tvs have a smart link on HDMI 1 that auto wakes the component connected to it but I dont know your situation.
Sep 20, 2014 | Panasonic Televison & Video
how to connect blu ray player hdmi to my laptop
1) Look at your laptop computer to see if you have an HDMI cable port. This port is roughly half an inch wide and provides both the HD audio and video signal. If you don't, you are going to use a DVI port on the laptop. This is the same port you use to connect monitors to your computer.
2) Plug the DVI-to-HDMI adapter into the DVI port on the laptop with the Blu-ray player. If you have an HDMI port on your laptop, you can skip this step.
3) Connect an HDMI cable to the HDMI end of the adapter. If you have an HDMI port, plug the cable directly into the HDMI port.
4) Plug the other end of the HDMI cable into the HDMI port on the HD television. Power on your television, press the "Input" button and select "HDMI." You can now see the contents from your Blu-ray player on the TV.
Thanks for rating
Good luck
Feb 11, 2011 | Televison & Video
i have purchased the blu ray dvd player do i need to by a coaxial jack as well as the hdmi jack
No,a HDMI cable alone will do the job.Just plug the HDMI cable one side connected to the HDMI port hub belong to the tv HDMI hub,the other side of the HDMI cable connected to the HDMI port hub belong to the Blu ray dvd player HDMI port hub.That should play ur Blu ray dvd player.U still have questions,read ur owner manual.
Jun 24, 2010 | Televison & Video
I continue to have to switch my HDMI cable between 2 ports on my TV because initally there is "no signal". But when I switch ports I get a signal. So is this a HDMI cable issue, port issue or my Insignia Blu-Ray disc player issue?
My best bet would be a port issue - see if another device will work plugged into that port. (Some HDTVs have a HDMI port strictly for Service and nothing else but a Technicians specified cable will work in this port, look at the Manual) Check to see if your TV is set to the same port as your connecting to. One will be HDMI 1, next HDMI 2 and so on, the input button on remote should switch from port to port, make sure port setting on TV is same as #port your connected to.
Jun 17, 2010 | Insignia NS-BRDVD Blu-Ray Player
Hd picture
Your TV does not support 1080p thats why, just adjust blu-ray and PS3 resolution down and it will work
Jun 01, 2010 | Sony STR-DG820 Receiver
2,696 people viewed this tip
Henry  Thomas
Henry Thomas
