Tip & How-To about Samsung RS2630SH Side by Side Refrigerator
Samsung RS24 through RS27 Repair Manual
Here is the Link for the Repair Manual for Samsung Side by Side Refrigerators with the model numbers that start with RS24 through RS27
Thanks
Samsung RS2630SH Side by Side Refrigerator Logo
I need a REPAIR manual, not an owner's guide. Is there one available?
Hello. Yes there is a repair manual for each appliance. Get back on here with the brand name and model number of your appliance and one of the experts will provide you with a link to a repair manual.
Thanks for choosing Fixya! Joe
Dec 06, 2010 | Refrigerators
Our refridgerator is not getting cold! it is staying at 60 degrees.. we tried cleaning out the back fan, and also tried resetting the temperature gauge but it keeps going back to 60 degrees and it blinks....help? this is for a samsung side by side model RS267LBBP.... THanks!
Please double check your model number because that number is not listed. I am pretty sure it has a dual evaporator one for freezer and other for the fresh food compartment. Check behind the cover of the fan inside the fresh food compartment to see if the coils are icing over. Send me the correct model number will help me decide if it is something different. I will even send you a Service manual with the correctmodel number, Thanks, Sea Breeze
Feb 12, 2010 | Samsung RS267LBBP 26.1 Cu. Ft. Side by...
SAmsung Service Manual
I fixed my problem with the fan not working in the refrigerator section. It ended up being the fan motor. The way I nailed it down was to temporarily switch the wires to the fan motors in the connector on the circuit card. This electrically powered the freezer fan from the refrigerator side and visa versa. The fan still worked in the freezer side (running of the refrigerator circuit) and was still inop on the refrigerator side proving that there was nothing wrong with the circuit card or possible other factors driving that circuit (other than the fan motor). I ordered and installed a new fan motor (about $50) and now everything works fine. It seems that the original problem caused the circuit card to shut down voltage to the bad fan motor that's why when you checked the voltage from the circuit card, it was nill causing you to falsely believe that it was not the fan motor. Yes, I did a resistance check on the fan motor and it was very close to being the same as the freezer motor (same part number).
Jun 03, 2007 | Samsung RS2630SH Side by Side Refrigerator
5,243 people viewed this tip
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
