Tip & How-To about D-Link DPH-540
No special firewall rules needed for DPH-540 and Dlink DI-604 router
My DPH-540 works fine behind a DI-604 NAT router, without any special firewall configuration on the DI-604 (I connect to either RingCentral or SIPPhone). I hope to get another SIP phone and see if both phones can work simultaneously behind the NAT router; many web sites suggest that a different proxy port must be used (the default is 5060).
D-Link DPH-540 Logo
Switched internet service providers now the router doesn't work
You might want to check the routers settings to make sure that it is not configured to use PPOE connection which is for DSl and the Broadband connection. You can find the routers address by searching google. Linksys uses 192.168.1.1. You can always try resetting the router by pushing the reset button usually found by the power plug in the back.
Feb 19, 2009 | D-Link DI-604 4-Port Cable/DSL Router...
laptop can't connect to internet
1) Your Network or DSL router may have bad or missing information. Powercycle your router and/or rebuild the configuration in your router.
2) Double-check your cabling to the computer. Make sure you have the correct type of cabling, straight-through CAT 5 or possibly a crossover cable and try another cable or test the cable to make sure its working properly.
3) Check your network card to make sure its configured correctly and working properly. Many times setting the network card to 10Mbps/Full Duplex will solve this issue. To do this, open Control Panel, System, Device Manager. Go to the properties of the Network card, click on the Advanced tab and find the Link Speed and Duplex section. Change it from Auto Detect to 10Mbps/Full Duplex.
4) Check and test your firewall. Your firewall, especially if its a software firewall like ZoneAlarm, Black Ice, Norton Firewall or something else could be blocking the connection. Disable your firewall and test the connection. You may have to resolve the problem by even uninstalling and reinstalling the firewall.
5) Check your IP address assignments and workgroup settings in the computer for accuracy. Statically assign IPs to the computers in your network.
6) Reset your TCP/IP stack by downloading and running WinsockXPFix.exe a Visual Basic program designed to fix corrupted TCP/IP issues, host file problems and a variety of other connectivity issues.
Nov 19, 2008 | D-Link DI-604 4-Port Cable/DSL Router...
Router not allowing connection to sites
Turn off the router's firewall or allow for exceptions. Most downloads and other software than browsing use additional ports that the firewall is not allowing to pass thru.
Oct 01, 2008 | D-Link DI-604 4-Port Cable/DSL Router...
D-LINK DI-604 STATIC IP
Log into the router and go to the configuration page for your WAN port. Change the connection type to static ip.
Apr 02, 2008 | D-Link DI-604 4-Port Cable/DSL Router...
591 people viewed this tip
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
