F21 Error Code on Whirlpool Duet & Kenmore Elite Front Loader Washers
By
jsrock516
Rank: Guru
Rating: 96%, 6675 votes
posted on Jan 04, 2009
This advice is for Kenmore Elite and Whirlpool Duet model FRONT LOADERS displaying the “F21” error code.
“F21” is a Long Drain error.
If the drain time exceeds 8 minutes this error code will be displayed.
In addition, a “SUDS” error may also be displayed.
This may be an indication of a drain pump problem and/or clog in the drain line.
You will need to check the following:
- First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
- Check the drain hose to make sure it is not kinked or clogged.
- Check the electrical connections to the pump and ensure the pump is running.
- Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Was this helpful?18 people thought this was helpful
Comment #1
posted on Nov 21, 2009
By
workingdad
Rank: Apprentice
Rating: 0%, 0 votes
Thank you so much this helped my problem, all fixed now, blessed your kindness, merry christmas to all
Comment #2
posted on Nov 08, 2009
By
daisy1643
Rank: Apprentice
Rating: 0%, 0 votes
Yeah! Thank you! Totally fixed the problem - Found 1 dinosaur sticker and a wash cloth
Comment #3
posted on Oct 23, 2009
Wow, so helpful. Baby socks and dryer sheets. Thanks!
Comment #4
posted on Apr 19, 2009
By
viehweger
Rank: Apprentice
Rating: 0%, 0 votes
This fixed my problem exactly! baby clothes had wound up in the trap... ugh
Can you Help with these Washing Machines problems?
Kenmore Elite 45986 Front Load Washer
from a power surge i am pretty sure I have a circuit board...
i have had a kenmore elite smartwash for 2 years -- I do...
Our Kenmore Elite HE3T washing machine isn't spinning...
Have a F21 error code
opened door and water spilled out. Shut door and now...
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
(800) 357-1234
Welcome to Action Appliance Repair. We have...
