Tip & How-To about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
If you have a Chraftsman/Liftmaster not working
If you have a Chraftsman/Liftmaster:
1.Check to see if the door is running correctly.
A. Run the door down and pull the emergency release. See if the door will run easily by itself.
1. If it runs hard by hand try lubricating the rollers and hinges with silicone spray or some form of lubricant (not WD 40)
2. If the door is heavy and falls back to the ground, you probably have a spring issue (either broken or needs more tension) in this case call a professional door repair company in your area.
B. If the door runs fine then check the up and down force on your operator (the box that hangs from the ceiling and reads Craftsman). If the light(s) on your operator go from front and/or back, the force adjustment screw is on the back of the operator. If the lights are on the sides of the operator then the force adjustment screw is on the right side (looking from the back of the operator and facing the garage door). Turn the light blue adjustment screw with the up arrow to a higher number.
C. If this does not solve your problem the top bushing could be going out of your operator. Open the case and see if a lot of black filings are on the top of the big gear. If so the gear assy. will have to be replaced part # 41C4220A
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
door won't open or close
1.Check to see if the door is running correctly.  A. Run the door down and pull the emergency release. See if the door will run easily by itself.
2. If the door runs fine your gears might br out of your opreator. Open the case and look for a white powder. If you see that and your gears look worn repace the gears with 41c4220a gear kit.
( with the 5 flashing the traveler is jammed up against the top bolt. The same part will fix the problem be sure to replace the bottom bushing on the motor bracket.)
Feb 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
The liftmaster garage door opener issues
2. If the door runs fine your gears might br out of your opreator. Open the case and look for a white powder. If you see that and your gaers look worn repace the gaers with 41c4220a gear kit.
Jan 07, 2009 | Sears Craftsman LiftMaster Chamberlain...
craftsman door opener jumps and drags
1. If it runs hard by hand try lubricating the rollers and hinges with silicone spray or some form of lubricant (not WD 40) And be sure you lubricate the rial and the chain on the operator
B. If the door runs fine then check the up and down force on your operator (the box that hangs from the ceiling). If the light bulb(s) on your operator are on the front and/or back, the force adjustment screw is on the back of the operator. If the lights are on the sides of the operator then the force adjustment screw is on the right side (looking from the back of the operator and facing the garage door). Turn the light blue adjustment screw with the up arrow to a higher number.
Jan 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door problem
Jan 04, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door closes 75% of the way and re-opens, light starts flashing.
If the door runs fine then check the up and  down force on your operator (the box that hangs from the ceiling). If the light bulb(s) on your operator are on the front and/or back, the force adjustment screw is on the back of the operator. If the lights are on the sides of the operator then the force adjustment screw is on the right side (looking from the back of the operator and facing  the garage door). Turn the light blue adjustment screw with the up (or down) arrow to a higher number.
Sep 21, 2008 | Chamberlain Powerdrive PD422D 1/2 HP...
1,463 people viewed this tip
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
