Tip & How-To about Palm Tungsten E2 Handheld
Formatting SD card for E2
1. Click on time in upper left corner
2. Select info
3. On device drop down select sd card
4. Lower right corner select MORE
5. Click on card info tab
6. Select Format
If it doesn't come up, the card is toast for this unit
Palm Tungsten E2 Handheld Logo
I can't figure out how to change from right hand click to left hand. Please tell me how to do it. thanks
start run control panel mouse/ buttons/ configuration
press ok............
cheers
Mar 27, 2011 | Computers & Internet
i have a tower computer kind of older . when i plug in the microphone to the back i.e. microphone port, nothing happens to signal it reads the microphone and when i try to use the microphone for fruity loops mixer program it wont work. I get nothing from the microphone and nothing on the tower to suggest it even reads the microphone.
Assuming you are running windows XP you need to
1. right click the speaker in the lower right corner and select adjust audio properties.
2. Select the audio tab
3. Pull the drop down menu under sound recording and make sure it is selected to your audio driver device. Most are either soundmax, creative(for soundblaster and audigy standalone cards), realtek, or ASUS.
4. Next repeat step one but select open volume control
5. Go to options and then properties
6. Select the circle for recording and make sure your mic input is checked.
7. Close that window and recording mixers will pop up. Select the input you need by checking the box in the lower left corner of the mixer channel. Adjust the level and then use your recording program or sound recorder under Program files>accesories>communication>sound recorder.
Mar 08, 2011 | Philips Phillips...
how do i change the lay out from english to portuguese on my yahoo account?
1) When logged into your Yahoo! Mail click on "Options" in the upper right corner, and select "Mail Options"
2) In the left pane, click "Accounts"
3) In the lower center pane, click "Add or Edit an Account"
4) In the left pane, click "Account information"
5) You may be asked for your password again
6) Find the section that pertains to timezone, layout, language - choose your options from the drop-down boxes (Yahoo! Portuguese does not exist - try Brazil)
7) Click "Finished" to save your changes
Feb 01, 2010 | Yahoo Mail
once I installed magic jack my computer speakers stopped working ... got a new sound card ... worked fine ..plugged magic jack back in ... they stopped working again ... online help ... hasn't helped yet .. they literally spent hours guiding me to reset .. reboot .reload ...uninstall ... reinstall ... download new things to no avail .. need help
Windows XP:
1. Click Start
2. Click Control Panel
3. If your Control Panel is in Category View, double-click Sounds, Speech and Audio Devices. If not, go directly to the step 4
4. Double Click on Sounds and Audio Devices
5. Click the Audio tab (the middle one)
6. Under both Sound Playback and Sound Recording, select your default audio device (the one you want to use) from the drop down menu
* Never select Tigerjet as your default device
7. Click the box labeled Use Only Default Device" (located in the bottom left corner of the window)
8. Click Apply and OK
Windows VISTA
1. Click the Windows Button (Old Start Button)
2. Click Control Panel.
3. If your Control Panel is in Classic View, Double-Click Sound. If not, go directly to the step 4.
4. Click on Hardware and Sound.
5. Click Sound.
6. Right-Click on your default device (the one you want to use) and select Set as Default Device
* Never select Tigerjet as your default device.
7. Click Ok.
www.sunwindproducts.com
Jan 12, 2010 | Audio Players & Recorders
Palm Tungsten e2 and duracell 1 gb memory card
Thall shalt format card for E2
1. Click on time in upper left hand corner
2. Select info
3. On device drop menu select sd card
4. Lower right corner select more
5. Upper right select card
6. Select FORMAT CARD
If you can't format...the card is toast
Dec 13, 2008 | LG Shine KE970 Cellular Phone
1,498 people viewed this tip
Top Palm Computers & Internet Experts
Michael Vincent Cruz
Raj Patel
Andrew Taylor
Andrew Taylor
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
