Tip & How-To about Microsoft ZUNE JS8BRPBDLUG MP3 Player
Zune 30GB Bug
There is a problem with these known as the Zune 30's y2k9 bug. If you call they will fix the problem for you . Call 1-877-438-9863 for zune technical support. I am expecting a recall but I am not sure what microsoft will do.
Microsoft ZUNE JS8BRPBDLUG MP3 Player Logo
Zune frozen,
The 30 Gig Zunes have a bug in how it processes the date. Per MS it will fix its self 1 Jan 2009
http://forums.zune.net/ShowPost.aspx?PostID=408989
Jim
Dec 31, 2008 | Microsoft Zune JS8-00001 Digital Media...
zune frozen with zune logo on screen
There is a problem with these known as the Zune 30's y2k9 bug. If you call they will fix the problem for you for free. Call 1-877-438-9863 for zune technical support.
Dec 31, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
my 30 gb zune is frozen
There's a fix:
Your zune will need a "hard reset."
To do this, use a small screwdriver to pop off the plastic shielding where the zune cable plugs into and remove the two screws on either side of the plug. Next pop the cover off and locate the battery plug at the top left corner of the zune, using your screw driver, pop the cable connection half way off, and do this to the other plug on the right side. Wait 3 seconds, then push down the right connector and then the left battery connecter. Your zune should start up immediately. Press the backing of the zune down (make sure headphone jack is aligned) and put the screws and cover back in place.
It's an easy process but if you're unsure don't attempt it.
zune not working
If these are the 30GB zunes there is a problem with these known as the Zune 30's y2k9 bug. If you call they will fix the problem for you for free. Call 1-877-438-9863 for zune technical support.
Zune 30g screen logo won't go away!
okay so the solution is that tomorrow your zune will reset itself about noon
742 people viewed this tip
Top Microsoft Audio Players & Recorders Experts
john h
Ap12
Ap12
Are you a Microsoft Audio Player and Recorder Expert? Answer questions, earn points and help others
