Tip & How-To about Philips Magnavox MWR10D6 DVD Recorder
Tuning in phillips dvd recorder
Make sure you select the correct country when setting up dvd - i used the quick install leaflet which did not mention that selecting the correct country you were in was very important. I nearly went demented trying to find out why i couldnt tune the dvd properly.
simple omission!!!! but very important
Philips Magnavox MWR10D6 DVD Recorder Logo
My samsung TV will only play DVDs in black and white.
ensure the country region on the samsung bluray is set correctly to your country and tv set (NTSC OR PAL) at setup,
menu/system/setup - select country correctly - and this should detect another TV device if correctly connected through HDMI, and start the anyconnect application, if your Tv is another model, it wont. if playing DVD's in black and white it seems you might be located in another region to which you purchased the bluray player and differs from the set. did you buy the Bluray from the same store as the set?....please dont say ebay !
Aug 02, 2014 | Televison & Video
I can't get my screen resolution set right on my HP 16 inch monitor
Hi there
It seems that your is that the correct graphics driver is not installed. You not mention any make or model of PC omain board, so all advice I can give is that you download the correct driver the main board manufacturers site if you do not have the install CDr the mainboard.
Regards
Andre
Sep 09, 2011 | HP Computers & Internet
Can't get tv audio through my Philips HTS3510.
Here is the user manual and quick start guide:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?slg=en&scy=ph&ctn=HTS3510/98
Be sure your connections are correct.
Press AUDIO SOURCE repeatedly to select
the audio output of the connected device (TV)
There could be audio settings on your TV which you can select only Internal or only external speakers or both. Be sure the setting is correct on your TV.
Be sure your TV and your HTS3510 are not set to "mute"... Don't laugh... I've done it before...
Jun 09, 2011 | Philips Televison & Video
641 people viewed this tip
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
