Tip & How-To about E-Machines eMachines Desktop PC
Emachine e4264 bios update
There is an updated version of the BIOS for emachine model e4264 that fixes some hardware compatibility issues as well as other things for windows vista.
There is a read file you can download here
As well as the driver here
To install the driver download then follow these steps
1. Use CDRW burning software to Burn Disc Image of the C:\Cabs\4GC3110E\4GC3110E.iso file to a blank CD. 2. After creating the bootable CD, place the CD in the CD/DVD drive, and then restart the computer. 3. At the Menu, select 1 for eMachines BIOS 4GC3110E. The BIOS flash process runs automatically. Do not press any keys or turn off the computer during this process. 4. When complete, the message "Flashing Complete" flashes. Remove boot media used and press the F1 key. 5. Press the F2 key to enter the BIOS Setup Utility. 6. In the BIOS Setup Utility, select Load Optimized Defaults, and then press the ENTER key. 7. Press the Y key, and then to select Load Optimized Defaults, press ENTER. 8. In the BIOS Setup Utility, select Save and Exit Setup, and then press ENTER. 9. Press Y, and then press ENTER to Save and EXIT.
E-Machines eMachines Desktop PC Logo
Bios update
BIOS updates are not necessary unless you have hardware compatibility issues or hardware related system instability. To obtain the most recent version of your BIOS (or any other downloads or info), go to Dell's website, click support and enter your model number, and it will show you anything you might need. Here is a link to the most recent BIOS update: http://www.dell.com/support/drivers/us/en/04/DriverDetails/DriverFileFormats?c=us&l=en&s=bsd&cs=04&DriverId=R106056#3DOSJust download the file and run it. It will do all the work for you!
Jan 07, 2012 | Dell Optiplex GX620 Pentium 4 3.4GHz (Open...
i have four sata ports inside my emachine desktop and my bios says not installed
If the SATA ports are showing not installed on the BIOS then it can be due to either older BIOS version or the Ports are not detected. I recommend to update the BIOS from the emachines website, please follow the link below:
htttp:\\support.emachines.com
Select the computer model and download the BIOS
It should take care of the issue.
Thanks and regards,
Jitha.G.J
Dec 20, 2011 | E-Machines eMachines Desktop PC
I have the same problem with my T3120 emachine.
could be a 'gray market' machine! i've run into this before- basically 'your motherboard/bios' doesn't exist- good luck! boot up should show what your bios version is, look for that, rather than your motherboard version!
'my computer'- 'properties'- should have your bios info on it. use that info to find updated 'flash', if it's available.
good luck!
Oct 08, 2009 | E-Machines eMachines Desktop PC
T2742 OEM Bios Update
I researched and could not find it. I suggest that you have a Chat session with the eMachine support @:
http://www.emachines.com/support/product_support.html
Or you can download BiosAgent and it will tell you what you need, but to download it, you would have to purchase it for a fee of $29.00. I download BioAgent and it told me what Bios and hardware updates I needed.
http://biosagentplus.com/?r=302&PHPSESSID=bt75epk9dugl4vj1fj1d9om4c5
copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 10, 2008 | E-Machines eMachines Desktop PC
2,844 people viewed this tip
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
