Tip & How-To about Eaton Home Heartbeat Water Shut-Off Controller
Eaton Home Heartbeat Water ShutOff Controller...
The Water Shut-Off Controller can be linked to HOMEheartbeat water sensors (HHBWATERSNSR) to automatically shut off your house's main water linein the event of a water leak. Simply place Water Sensors in high-riskareas for water damage. Then install your Water Shut-Off Controller onyour main water line and setup the unit to turn off if a Water Sensorbecomes wet. Then, when the icemaker malfunctions or the toiletoverflows your Water Sensor will become wet and your main water linewill close, minimizing the costly water damage.
NOTICE! This product requires installation of, and will only work with a HOMEheartbeat Ball Valve. Ball Valve installation may require professional plumbing assistance.
Important Note: Use of this product requires the purchase of the HOMEheartbeat Starter Pack
Review the User Manual at FixYa
Eaton Home Heartbeat Water Shut-Off Controller Logo
My hot point wma30 washing machine just keeps filling with water when switched of and Dior open
Turn off the water where the water comes out the wall. The hot and cold should each have a shut off valve...like your outside water where the hose hooks up. If the valves are frozen try moving them with a little force back and forth to see if you can get them to move. Do not break them. If they won't move then you'll have to find your main line shut off valve to shut off the water to the whole house.
I suggest calling a handy person to help you to shut off the water at the washer and then call a washer repair person to replace the internal washer shut off valve and/or sensor.
Mar 20, 2016 | Washing Machines
need to clean single knob shower cartridge from what i read - where do i shut off water first? hot water running to bathroom - sink gets it - in shower, cold water good, hot water trickles - read lots of posts and feel comfortable disassembling the knob, but don't know where to turn off water supply first as suggested
To clean it, shut off the discharge valve at the water
heater. Then, you shut the valve off of the main water supply. After which, you can start cleaning the single
knob shower cartridge. After the cleaning job, you can
open the discharge valve of the water heater, then, the
valve of the main water supply.
Nov 11, 2009 | Moen & One Handle Tub & Shower Faucet
water won't stop running in ice maker & the freezer is overflowing with water . had to turn off water main to the house to stop the overflow of water.
Hello, This sounds like its going to be the inlet valve stuck in the open position. For now locate the water shut off for the ice maker by following the pipe into the basement or to where ever it goes. There should be a shut off valve so you can get the main water back on in the house. Your going to need to replace the valve which is normally located behind the panel at the back of the refrigerator. If you have any other questions please feel free to comment. Mike
Oct 18, 2009 | Frigidaire Freezers
365 people viewed this tip
Top Eaton Home Security Experts
Lawrence Oravetz
Are you an Eaton Home Security Expert? Answer questions, earn points and help others
