Tip & How-To about Eaton Home Heartbeat Reminder Sensor
Eaton Home Heartbeat Reminder Sensor Description
The Reminder Sensor can be used as a "reminder alarm clock". Choosefrom one of 29 preset alert messages and a time interval and theReminder Sensor will do the rest. Click the sensor to start the timer.Then when the time is up, you'll get a reminder alert. Then simplyclick the sensor again to restart your timer.
Important Note: Use of this product requires the purchase of the HOMEheartbeat Starter Pack
Review the User Manual at FixYa
Eaton Home Heartbeat Reminder Sensor Logo
TEXT ALERT
I use SMS Popup (from the Play Store) for repeating text message reminders. It has other functions, but I primarily use the 'reminder' options. I'm not sure if you could (or should) do 5 to 10 second intervals as it would probably kill your battery. I think that 1 minute is the minimum. I guess you could also use a notification sound that is longer. You could even record your own. I once recorded myself coughing and used it as the notification.
Feb 08, 2014 | Samsung Cell Phones
GE Spacesave microwave won't work. Display says REM. What does that mean?
"REM" is "reminder". That's covered in your owner's manual.
Here's a sample:
"The Reminder feature can
be used like an alarm clock
and can be used at any
time, even when the oven
is operating. The
Reminder time can be set
up to 24 hours later.
1 Press REMINDER.
2 Enter the time you want
the oven to remind you.
(Be sure the microwave
clock shows the correct
time of day.)
3 Select AM or PM.
4 Press REMINDER. When
Reminder signal occurs,
press REMINDER to turn
it off. The Reminder
time may be displayed by
pressing REMINDER.
NOTE: The REM indicator
will remain lit to show that
the Reminder is set. To
clear the Reminder before
it occurs, press
REMINDER, then 0. The
REM indicator will no
longer be lit."
Jan 27, 2011 | GE Microwave Ovens
What does perform service message mean?
This is a oil change reminder. Nothing fancy about, when you get your oil change go into the menu and click reset counter and it will go off. If there was something wrong with your car the check engine light would come on.
Apr 15, 2010 | 2002 Jeep Grand Cherokee
alarm clock
Try using Datebook, it isn't exactly an alarm but you can program reminders and apply them daily, work days, multimple days (allowing you to choose which days you want to be reminded), weekly, day per month, or even yearly.
Mar 25, 2009 | Motorola Mobility I335 Cellular Phone
mobile
Hi, I don't think it has the function to set for individual days but as an alternative you could try going in to the calendar and setting up a date/time and setting up a reminder alert. You can change the alert to custom time of your own. i.e 1 minute prior. not ideal as more fiddley way AND you would think such a phone would have function to set alarm for other days. anyway hope this helps.
Sep 17, 2008 | Motorola Mobility MOTORAZR2 V9 Cellular...
342 people viewed this tip
Top Eaton Home Security Experts
Lawrence Oravetz
Are you an Eaton Home Security Expert? Answer questions, earn points and help others
