Tip & How-To about Eaton Home Heartbeat Open/Closed Sensor
Eaton Home Heartbeat Open/Closed Sensor Description
The Open/Closed Sensor can be attached to a window, door, cabinet,or anything else that you want to monitor the open/closed status. Itworks using a magnet and switch. When they are close together thesensor recognizes that the door or window is closed. Likewise, if thetwo pieces are far apart, it recognizes the door or window is open.
Important Note: Use of this product requires the purchase of the HOMEheartbeat Starter Pack
Review the User Manual at FixYa
Eaton Home Heartbeat Open/Closed Sensor Logo
Hi I have a 2006 Lincoln navigator the air suspension pump will not turn on the vehicle dynamics module is not turning on the pump relay because in the pid data the drivers door says it is ajar when it is actually closed,but in another module the vehicle security module the pid data says the door is closed and changes as the door is opened or closed if I am correct if there were a can bus wire problem I wouldn't be able to communicate with either module do you have any ideas
Hey Jeff, any U- codes stored in any modules ?
U1900 Missing CAN message(s) Door(s) ajar, PRNDL, 4x4, instrument cluster (IC), running boards, vehicle speed REFER to Section 418-00 . U2023 Invalid CAN message(s) Door(s) ajar, PRNDL, 4x4, instrument cluster (IC), running boards, vehicle speed REFER to Section 418-00 .
L4 CHECK THE VDM FOR DOOR AJAR INPUT
  • Key in ON position.
  • Monitor VDM door position status PID.
  • Close all doors, liftgate, liftgate glass and power running boards.
  • While observing the diagnostic tool, open and close one door.
  • Does the door status PID change between CLOSED and AJAR states?
When you open an close the driver door you have no PID change ,right ?
The door ajar input is an input to the Vehicle Security Module , then transmitted over the bus ! You'll have to find a diagram for the med. speed CAN data bus .
Jan 09, 2015 | 2006 Lincoln Navigator
I have a problem with the door monitor for my Craftsman 1/2 HP 315MHz garage door opener. I recently had my garage door changed and now the monitor indicates the door is open when it is closed and closed when it is open.
It sounds like the sensor on the top section of the door may be mounted upside down. If you can, remount it right side up, and see if that corrects if the problem. If not, contact me directly.
Sep 11, 2013 | Chamberlain Sears Craftsman Liftmaster...
Kitchen cabinet doors pop open
If the hinge is out of alignment, or simply worn out, replacement may be necessary. But, if the problem is the cabinet door (warped, or enlarged screw-mount holes) a new hinge will give you the same issue you have now. A small magnetic catch may resolve your issue with less expense and no alignment needed. It involves a small (1" square) metal plate with a single screw which you attach near the the lower corner that hangs open. The complimentary magnet attaches to the door frame of the cabinet housing (inside the cabinet). Available at even small hardware stores, the catches cost about a buck, install in a minute or 2, and will discretely solve the problem shown in your video.
May 05, 2013 | Hardware & Accessories
why does my printer status read "door open" but
Hi,the printer has a sensor that makes sure the the door is completely closed. In any case that it is indicating that the door is open, there could be an issue with the sensor. I suggest you contact technical support from the manufacturer of the printer to give you solution for the issue.
Thank you for using Fixya. Your recommendation is highly appreciated for the free support.
Sep 29, 2011 | HP PSC 1210 All-In-One InkJet Printer
hi I'm still getting a false open door reading
The sensor for the door that is indicating may have some dust or dirt on it. use can air. if not sensor is bad, also check for any broken parts on the door, that mite have been the actuator for the sensor to tell the copier the door was closed. Some machines in service mode have a sensor check test, that allows you see if the sensor is working
Aug 13, 2009 | Ricoh Office Equipment & Supplies
393 people viewed this tip
Top Eaton Home Security Experts
Lawrence Oravetz
Are you an Eaton Home Security Expert? Answer questions, earn points and help others
